Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Export Radios
Amateur Callsign Lookup
Enter Callsign:
RCI-2995dx lo AM power = 0.3 watt with no mod, 40 watts with mod.
Reply
  #1
Old 12-07-2010, 01:48 PM
Rejean VE-2-EUI
GUDULE is on a distinguished road
Default RCI-2995dx lo AM power = 0.3 watt with no mod, 40 watts with mod.
A friend brought me his brand new defective radio to repair. ( 2 months old )
He lives in Canada, and dont want to ship it back to the US seller.
I get 110 watts in SSB when whistling in the mike.
Is this a common problem ???
Can someone help me with this problem ???
Thanks
  #2
Old 12-07-2010, 04:39 PM
Senior Member
DXman is on a distinguished road
Default
I do believe them radio's will get a good 200 out on ssb, so what your seeing is quite low. A friend here in the area has one of these and he is seeing a good 215 from his and that's on a good $450 meter.
Also - 215 is not with a whistle either, that's straight modulation!
__________________
5 element Yagi since '76 on one tower/I 10K the other tower.
214 DXCC - 11 mt. (no amps used on base for the last 36 yrs)
  #3
Old 12-07-2010, 05:59 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
215 watts?? Is this with an external power supply?? I also thought they still used a pair of 2SC2290 transistors as they did with the 2990 and 2970? Maybe someone else will chime in I wasnt aware these newer DX models put out that much power.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #4
Old 12-08-2010, 06:04 PM
Senior Member
hotrod is on a distinguished road
Default
Thanks
does this have the old 2x2290 setup or newer mosfets?
was this measured with a dummyload.
what type of meter pep or rms
make sure power and mikegain at fully clockwise
if it has 2290s in it this is pretty accurate
but if it the newer mofets should do bout 200
im not sure how you,d tell which ya got maybe
someome smarter than me can help ya figure this out
__________________
BASE-emperior 5010,sirio 2016
MOBILE-ss3900,sirioz180,astatic 636SE
  #5
Old 12-08-2010, 06:29 PM
kevin IB/379 Stringbean's Avatar
Senior Member
kevin IB/379 Stringbean is on a distinguished road
Default
Post the serial # and someone will be able to tell you which model you have by that.You might even email Ranger and give the # to them and they'll tell you.
But being that its only 2 months new,I'll go out on a limb and say its mosfet though provided its only 2 months old.If it has the computer style switching power supply with a fan,this is a good indicator of mosfet.
  #6
Old 12-09-2010, 03:46 PM
Senior Member
9C1Driver is on a distinguished road
Default
I looked at the RCI home page and they make no mention of a mosfet re-design. I assume they are still a pair of 2290's for now. When the 2970DX went to mosfets they changed the model number to 2970N2. I'm thinking they would do the same for the 2995DX. Not sure.
With all the problems these had years ago with power supply failures I would not want one all wound out. With a nice tune and alignment something in the 150-175 watt range would be ideal. I know alot of shops like to quote 200+ watts from these but I just don't know.
cb tricks has the alignment procedures for this radio, very in depth process. Here is the link. Ranger RCI-2995DX
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Here's another $10,000 fine to a CBer! C W Morse FCC & ARRL Activity 10 12-17-2011 05:23 PM
2995dx power supply problem zinger827 General CB Services Discussion 12 05-05-2009 02:27 PM
Interesting reading, datsun66 General Ham Radio Discussion 3 08-16-2007 08:16 PM
formula? Lazybones1222 CB Band and CB Radios 5 01-13-2005 02:53 PM
Powered by vBulletin®
