WorldWide Radio Forum
Go Back   WorldWide Radio Forum > General Discussion > FCC & ARRL Activity
Notices
FCC & ARRL Activity News, info and publications that effect the radio hobby.
Reply
  #11 (permalink)
Old 04-05-2008, 08:46 AM
AudioShockwav's Avatar
Senior Member
AudioShockwav is on a distinguished road
Default
Quote:
I guess the question would be is Texas Star authorized to distribute or sell these amps, if no why continue? When I worked for PDC, we also housed Vectronics, in which their amps could be modified by the end-user (at that time) for use for 10-meters, but the amps were actually FCC certified with traceability.
Texas Star skirted around the certified process by building them as CW transmiters.
When Sold they are actually 10 meter cw transmitters when they are shipped from the supplier.
There is an input for a CW key, and inside of the unit is a small oscillator board with a crystal which puts the output somewhere in the cw portion of the 10 meter band..
As they come from the factory they will not function as an amplifier, and regardless of the size of the unit, the maximum output is in the neighborhood of 5 watts. To convert these to an amplifier, which most people do, involves a series of modifcations that are more complicated that expanding the transmit capabilities of most newer HF All mode radios.
Instead of clipping a single diode, the oscillator board must be removed and wires connected to certain areas of the switch panel
I have seen shops around here that will keep the "export" stuff in the back, but there are a few of these units under glass in the store front.
There are not the restrictions written into the rules that effect CW transmiters, like Amps and 10 meters radios that are easly converted to Cb use, so called "dual use" radios.....they found a spot in a different category.
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/javagif/gifs_thumb/20080120_1300_eit_171.gif
NASA/SOHO
  #12 (permalink)
Old 04-05-2008, 09:39 AM
Senior Member
Geekster is on a distinguished road
Default
Ahhh I see, a loop-hole quite possibly. I remember that the Vectronics amps had a lockout device for the 10 meter band and there was a process where one had to contact the factory and certain paperwork involved.
Thanks for the info!
__________________
I geek therefore I am...
I geeked therefore I were...
"Fides Quaerens Intellectum"
  #13 (permalink)
Old 04-05-2008, 08:16 PM
Senior Member
4600turbo is on a distinguished road
Default
You holier than thou guys just crack me up.
It's ok to covert a ham radio to talk on 11meter but not the other way.
Even though the Lic. required to run a ham radio is easy to get.
I bet a lot of you were crying when the Morse code restriction was lifted. HaHaHa.
Then your ecstatic about someone getting fined. I'm sure you guys run 10 meter radios in your personal vehicle.
  #14 (permalink)
Old 04-05-2008, 09:45 PM
74IN's Avatar
Senior Member
74IN is on a distinguished road
Default
You just don't get it.
Why don't you spend the $$$ for a SuperWhackPack?
It's a rip off.
It's good to see a scam artist get what he deserves.
Or do you not agree?
__________________
  #15 (permalink)
Old 04-05-2008, 09:48 PM
74IN's Avatar
Senior Member
Default
Is this "holier than thou?"
http://cbretards.com/scumbags/scumbags.htm
__________________
  #16 (permalink)
Old 04-05-2008, 10:15 PM
Senior Member
C W Morse is on a distinguished road
Default
Yes, it IS! That's because the amateurs generally follow the law, and because they DO test on their technical AND regulatory knowledge, they are expected to toe to a higher standard. In fact, there are GOOD, solid, and LEGAL reasons to modify amateur equipment.
1). To take advantage of the 60 Meter band that does not come already enabled. LEGAL
2) To participate in Army, Navy/Marine Corps & USAF MARS. LEGAL with authorization from State MARS & and National MARS HQ.
3) To participate in FEMA and other agencies" HF communications on designated HF frequencies. LEGAL with authorization and proof of NTIA compliant equipment from designated authority.
4) To participate in Homeland Security exercises, military and shared traffic nets Appointment and authorization from the correct military agency.
5) To assist in emergency operations requiring operations on a wide variety of HF frequencies--many of whom are not widely known nor are permitted to be shared with others due to Operational Security restrictions. (See #4)
6) To participate in specific communications activities of both civilian and military agencies as needed--some of which FCC has absolutely no sayso in! (See above # 4 & 5
7) Because such modifications are encouraged by the agencies who receive assistance from mature, dedicated amateurs and communications volunteers who are serious, semi-professional communicators that can be counted on in a pinch when the ball drops.
TOO easy. Has nothing to do with elitism, but with technical and operational standards.
I didn't have to wait because *I* couldn't master it back in the 80's.
(See comments interspersed above)
Wanna know WHY? Because it is these people who facilitate the THEFT of radio spectrum from legitimate, LICENSED users! They DESERVE to get popped and MORE! If they'd just at least TELL their customers NOT to stray onto 10 Meters, that'd help. Or disable the sets so they only work on 11 Meters. BUT NOOOOOO! We don't CARE about anything LEGAL: we just want to make a fast buck. Who CARES if our customers interfere with the hams! NO sympathy from me!
Run one of those &^%$% things in MY vehicle?? Don't even START me telling you what I REALLY think of 'em! BUNCHA *&^%$(*---SHHHHHHHHHHH! BE nice now!!!
  #17 (permalink)
Old 04-06-2008, 06:36 AM
Junior Member
Trouble is on a distinguished road
Default
From my personal experience with RA, he does strongly admonish cb customers from using the other bands on the export radios. He has shown strong support for the ham community (in my experience). Anyway, my two cents worth. Maybe others have a diff. opinion, but, what "radio shop" doesn't operate in this gray area?
  #18 (permalink)
Old 04-06-2008, 07:02 AM
Senior Member
Sonwatcher is on a distinguished road
Default
I think this is incorrect. An Amateur can convert a CB to talk on HF.
__________________
  #19 (permalink)
Old 04-06-2008, 07:11 AM
Senior Member
W5LZ is an unknown quantity at this point
Default
Sonwatcher,
You're right. It's legal for hams to convert anything to use on bands they have privileges on. May, or may not, be a good idea, but it's legal.
Rules/laws are two sided. The may restrict you, but they also protect you. It's your choice, but you gotta accept the consequences.
  #20 (permalink)
Old 04-06-2008, 09:53 AM
GLR GLR is offline
GLR is an unknown quantity at this point
Default
Quote:
Michael T Kersnowski owner of radioactive is a licensed ham.
Callsign - KC2AXD
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
