(They keep telling me
FCC ain't got time to mess with CBers)
FEDERAL COMMUNICATIONS COMMISSION
ENFORCEMENT BUREAU
NORTHEAST REGION
Detroit Office
24897 Hathaway Street
Farmington Hills, Michigan 48375
April 2, 2008
(Sent via Certified Return Receipt Requested and First Class U.S. Mail)
William VanTiem
Lexington, MI
NOTICE OF UNLICENSED OPERATION
Case Number: EB-08-DT-0055 Document Number: W200832360010
The Detroit Office received information that your Citizens Band ("
CB") Radio Service station was being operated illegally and causing interference in Lexington, Michigan.
On March 26, 2008 agents from this office attempted to inspect your
CB station but you weren't available. In a subsequent telephone call on March 28, 2008 with one of the agents, you admitted using a 350 watt
CB linear amplifier. Section 95.411(a)(1) prohibits the use of external radio frequency power amplifiers (sometimes called linears or linear amplifiers). 47 C.F.R. S: 95.411(a)(1). Section 95.411(b) of the Rules provides that "use of a power amplifier voids your authority to operate the station." 47 C.F.R. S: 95.411(b). By using a
CB linear amplifier, you voided your authority to operate this station. Radio stations must be licensed by the
FCC pursuant to 47 U.S.C. S: 301.
You are hereby warned that operation of radio transmitting equipment without a valid radio station authorization constitutes a violation of the Federal laws cited above and could subject the operator to severe penalties, including, but not limited to, substantial monetary fines, in rem arrest action against the offending radio equipment, and criminal sanctions including imprisonment. (see 47 U.S.C. S:S: 401, 501, 503 and 510).
UNLICENSED OPERATION OF THIS RADIO STATION MUST BE DISCONTINUED IMMEDIATELY.
You have ten (10) days from the date of this notice to respond regarding the operation of your
CB station. Your response should be sent to the address in the letterhead and reference the listed case and document number. Under the Privacy Act of 1974, 5 U.S.C. S: 552a(e)(3), we are informing you that the Commission's staff will use all relevant material information before it to determine what, if any, enforcement action is required to ensure your compliance with
FCC Rules. This will include any information that you disclose in your reply. You may contact this office if you have any questions.
James A. Bridgewater, District Director
Detroit Office
Attachments: Excerpts from the Communications Act of 1934, As Amended Enforcement Bureau, "Inspection Fact Sheet", July 2003
CWM
