Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
DaveMade,Fatboy or Xforce
Like Tree1Likes
Reply
  #9
Old 09-13-2011, 03:35 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Quote:
Originally Posted by ElectronTubesRule View Post
You know I do not know if you have thought about this but if you did get a tube amp with 811A's you could always upgrade to 813's I think and get even more power out latter on if you wanted to. You can not really jump up much better in a Bipolar HF transistor then the 2SC2879 it is about as good as it gets until you step up to 24VDC or 50VDC and then you are not looking at Bipolar transistors either so the entire amp would not be right for the new transistors.
Just something to think about? Also you know you can buy an auto-tune board for the input side of any tube amp. The 2008 ARRL Hand Book has an amp project that features one and they give the name and adress I think of the company. They sell the board separately for those that want to work it into their amp or as black box. Might look into that if the only thing you hate about tube amps is the constant tune and load tune and load etc....
The upgrade for the 811A's are 572B's. Drop in replacements except the IMD is a little worse due to the tubes not running at optimal plate voltage. The 813 is a different animal altogether.
Also if you mean the AT-100AMP auto tuner from LDG Electronics, it was discontinued a few years ago much to the dismay of many homebrewers.
__________________
Marriage is like a deck of cards. In the beginning all you need is two hearts and a diamond. By the end you wish you had a club and a spade.
  #10
Old 09-13-2011, 05:17 AM
Senior Member
fnkycoldmedina is on a distinguished road
Default
a davemade will have a higher resell value down the line and will sell faster than any of the other amps mentioned .
but if ssb operation is a must for you then xforce be the way to go .
  #11
Old 09-13-2011, 08:10 AM
psycho's Avatar
Supporting Member
psycho is on a distinguished road
Default
Quote:
Originally Posted by ahanway View Post
I'am in the market to get a base amp and a mobile amp.Witch of these builders would give me the best customer service,best product and best bang for the buck?
The Fatboys are the most neatly assembled amps of the 3 mentioned. Performance wise they are all the same. Customer service wise....1) Fatboy 2) X Force 3) Davemade.
If you run the amps properly and don't run them on more than 15 volts, they should all live a long life.
__________________
Stop staring at me!
  #12
Old 09-13-2011, 08:13 AM
psycho's Avatar
Supporting Member
Default
Quote:
Originally Posted by mackmobile43 View Post
Call Joe and ask him to add biasing to one, I know, he'll grumble but that's what his job is.
He'll grumble then the call will end.
__________________
Stop staring at me!
  #13
Old 09-13-2011, 08:19 AM
Senior Member
cbradiomagazine.com is an unknown quantity at this point
Default
Xforce amp quality has been hit or miss over the last couple of years. If you can find a older one then they were quite good amps.
__________________
Visit my website - www.cbradiomagazine.com
  #14
Old 09-13-2011, 08:22 AM
K1MIZ's Avatar
K1MIZ is on a distinguished road
Default
Maybe you should define your operating style..ssb? AM? Cb? HAMRADIO? I will assume this amp is for CB and for AM since thats what most of the amp questions come from is AM CBers and w that said, Dave Made all the way. If your into SSB then stay away from Dave Made. If for SSB maybe you would consider a Texas Star amp. I own one specificly for SSB on the chicken band and nothing but bells and whistles.
Do your homework.. as someone stated above this topic has been beat to death. There are 20or so forums out there to join and read up on this topic..
__________________
WALKING THE DOG TREE TOP TALL
  #15
psycho's Avatar
Supporting Member
Default
The Davemade amps only have better resale is because most Davemade users suffer from a mild dose of brainwashing. "Davemade amps produce louder audio" "Davemade amps do more watts than the others" are among the more interesting misconceptions.
I have owned Davemade, fatboy, Magnaforce (X Force), and Worldwide amps....they all perform the same on AM. When Worldwide was in full swing with their amp building their customer service was by far the best.
__________________
Stop staring at me!
  #16
Old 09-13-2011, 10:00 AM
Junior Member
Kirk is on a distinguished road
Default
I'm very happy with my Davemade base amp. It runs (4) 4cx250b. Great amp
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Xforce X200 3 pill amp FS/FT Bigradioman CB Radio Gear SwapShop 1 02-22-2011 08:18 PM
XForce XT400 blaine CB Radio Gear SwapShop 34 07-29-2010 01:20 PM
XFORCE amps discintinued by ampsrus.org???????? chale Amplifiers 40 05-02-2008 06:49 PM
xforce 20012 base novakor General CB Services Discussion 2 02-16-2008 01:10 PM
XForce Section change Moleculo Announcements & Open Forum 2 03-15-2005 02:50 AM
Powered by vBulletin®
