Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Galaxy DX-88HL weak finals?
Reply
  #1
Old 11-19-2011, 08:21 AM
RatsoW8's Avatar
RatsoW8 is on a distinguished road
Default Galaxy DX-88HL weak finals?
Since its starting to get to cold to ride my harley I starting looking for a few project radios to keep me busy indoors this winter. I traded a guy another CB for an 88HL. and received it yesterday. Not a bad radio.
The rig has an issue with very low output. 2 watts AM and 2 pep in SSB mode. I did the tx alignment this morning and found the driver bias barely able to make 50ma. Can't get the final bias set correctly. I can get V10 to bring up the bias current but V20 has no effect at all on the driver bias. The collectors of TR51,44, 43 and 56 are only showing 4V and they should read approx 6.5V. Maybe the Voltage regulator is bad??
I also repaired a cracked band board so I'm seeing all frequency bands now which was another issue at first.
I started out seeing about 2 watts AM and 2 watts pep on SSB. After trying the alignment it's doing about 6 watts AM but, still 2 watts SSB. Nice receive though and the frequency counter seems to be spot on.
Anyone else have one of these and had issues with output/finals? Just looking for other ideas before I order the VR and finals for the radio.
__________________
Closet Biker, CB'er and snooty Ham!!
20 wpm Extra
  #2
Old 11-19-2011, 12:05 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Im almost thinking its a Voltage regulator issue I would first look at the solder joints in that particular area to start out. When you were checking voltage did you flex or push around on the board to see if any changes for better or worse??
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #3
Old 11-19-2011, 12:10 PM
RatsoW8's Avatar
Default
Quote:
Yep..did all that and I found couple new 2SC817 votage regulators in my drawer so I replaced it. Still seeing 4 volts on the collectors mentioned above.
__________________
20 wpm Extra
  #4
Old 11-19-2011, 12:18 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
If you are seeing 5 watts; then I do not think it is the final.
Sounds like this radio has received a lot of rough treatment - eg 'the cracked board'.
I would use that reasoning to look for other abuse in the driver/predriver stage.
Or more cracked trace(s).
Look for 'mods' or bad solder joints.
Have/use a DX 99V in my mobile - same board/radio . . .
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #5
Old 11-19-2011, 05:06 PM
TonyV225's Avatar
Default
Those are old radios and most have been bounced around dropped golden screw drivered ETC it sucks but its gonna be a rat race tracking the problem down. Ive seen these with hairline cracks in the boards from age and pi$$poor soldering ontop of it all. maybe BOB85 will stroll in and may have an idea
__________________
  #6
Old 11-19-2011, 05:15 PM
RatsoW8's Avatar
Default
Thanks guys. I'll keep checking things until I find it or someone chimes in.
__________________
20 wpm Extra
  #7
Old 12-01-2011, 06:35 AM
RatsoW8's Avatar
Default
Ha! Took a little time and testing but I discovered the problem is bad final output transistors. the driver was fine. I found one of those RFX 75 final modules on ebay for cheap so I bought it.
Piece of cake installing on a 36XX board. No extra components needed and it only took me about an hour last night to do the work. I haven't done the TX alignment yet but I'm initially seeing about 50 watts AM and 70 pep on SSB (on 10 meters of course).
The receive on this radio tracks right along with my Kenwood TS-140S and doesn't drift at all. I may very well retire my trusty HR-2510 from mobile duty and put the Galaxy in the truck.
Anyway, it was fun to tinker with.
__________________
20 wpm Extra
  #8
Old 12-01-2011, 02:46 PM
Senior Member
9C1Driver is on a distinguished road
Default
That sounds like a good way to fix that old beast up, the RFX-75. That said I would not be in a rush to replace the 2510 unless you talk mostly AM and love trucker echo with talkback. If you are a dedicated sidebander the Galaxy 88 will show it's true colors in the mobile this winter. The word sailboat comes to mind. Cool project though, I like what you did.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cobra 148GTL VS. Galaxy DX-949 CTStallion CB Band and CB Radios 51 08-20-2012 11:37 PM
GALAXY DX 88HL ????? Switch Kit CB Band and CB Radios 12 09-21-2011 12:51 PM
GALAXY 88HL AM POWER CB Band and CB Radios 11 11-27-2010 08:50 AM
New Galaxy DX2547 with IRF520 Mosfet finals movrider CB Radio Modifications 6 12-18-2009 08:59 AM
Cobra 29 adding Galaxy Finals 29LaidBack29 CB Band and CB Radios 1 02-08-2005 04:35 PM
Powered by vBulletin®
