Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
PALMOAR 450 HD
Reply
  #1
Old 11-24-2011, 04:41 PM
pimphand442 is on a distinguished road
Post PALMOAR 450 HD
I was diggin through some old cb stuff of mine and found an old palomar 450 elite hd 4 pill sd1446 and was wondering can anything be done to it for more power what should i run into it and expect out of it i just want to do some good dx'ing with my old amp palomar 250tx i was pushin 175watts with my 148 with it off i deadkey at 4 watts and swing to 13 watts but when i turn amp on i dk at 175 and when i talk it swings backwards to about 150 i dont know why? any help would be appriciated im not sure what its going to do with this 450hd but what causes backswing when amp goes on ? thanks
  #2
Old 11-24-2011, 05:04 PM
Senior Member
Mr Clean is an unknown quantity at this point
Default
Drop your dk to 1 to 1 and a half watts. Get your pep up some on the radio.
  #3
Old 11-24-2011, 05:07 PM
pro151's Avatar
Supporting Member
pro151 is on a distinguished road
Default
The HD on this amp really stands for "Hardly Drive". Do as said above and never exceed 1.5-2W DK or you will allow all of the magic smoke to escape.
I know because I own one.
__________________
MASTER TROLL
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
  #4
Old 11-24-2011, 05:18 PM
Senior Member
9C1Driver is on a distinguished road
Default
The only way you could see more peak power from the amp is run a radio that swings 20-25 watts. Amplifiers are what they are and for the most part there are no "magic mods" that all of a sudden make them do 500 watts. It does not work like that. With those Palomars run it on the Med power setting and go with it, don't get so caught up in the number you see on a watt meter.
To maximize the output for any amp make sure you have a good battery and alternator that can produce enough amperage. Run the proper gage wire to the amp. Make sure your antenna system is in order and can handle the power.
  #5
Old 11-24-2011, 05:49 PM
Default
does anybody know where i can find the tuning mods for cobra 148 nw st radio? still dont know why it swings backwards on watt meter when amp is on when off radio swings forward
  #6
Old 11-24-2011, 06:07 PM
pro151's Avatar
Supporting Member
Default
Cobra 148NW ST
Check here.
__________________
MASTER TROLL
  #7
Old 11-25-2011, 01:04 AM
Senior Member
Default
Quote:
Your AM dead key from the radio is too high when this happens. If you must run the radio as is then run the amp on Low or Med. This will add some swamping resistors to eat up some of the excess carrier.
Your 148 is a low powered radio 12-14 watts peak on AM and 14-18 SSB is all they are intended to do. Find the VR pot that adjusta the AM carrier and lower it to 2 watts. Then set the amp on Med and have some fun.
  #8
Old 11-25-2011, 04:21 AM
Post
on ssb with out the amp on it will deadkey at zero and swing close to 25 watts i never checked on ssb till you mentioned ssb so i went to garage and checked just about 25 watts so my am power is too high? how can i lower it but keep the max forward swing i wouldnt mind 2 watt dk to 15 watt swing maybee possible? thanks
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mongoose 450 / Rebel TX500 Schematics wcsd106 General CB Services Discussion 6 04-17-2010 10:41 AM
Cobra XL 450 PAPA Amplifiers 10 03-15-2010 12:32 AM
WTB Cobra 450 XL Amp crkfngr CB Radio Gear SwapShop 0 12-02-2009 09:26 AM
Mounting Palomar HD 450 To 2000 GTL DJboutit General CB Services Discussion 1 05-05-2009 11:15 AM
galaxy dx 99 hl,palomar 450 hd! smsrobertks General CB Services Discussion 2 01-06-2009 01:55 AM
Powered by vBulletin®
