Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
need to get frequency readings... older used O-scope or NEW Chinese freq counter?
Reply
  #1
Old 12-25-2011, 06:58 PM
mr_fx's Avatar
Senior Member
mr_fx is on a distinguished road
Default need to get frequency readings... older used O-scope or NEW Chinese freq counter?
The biggest reason is I have a pair of President/Uniden HR2510 radios... and as such I can not get by with just using my FC390 anymore... lol
if you look at the alignment info it calls for an O scope... BUT, and Old O-scope might not be in proper working order... however an old O-scope can be had for a 20 dollar bill over here in the USA...
then there is the VC3165 Frequency counter, direct from China... usually this unit can be had for under $125 to your door, I have even seen it for as little as $89 shipped... it gets GREAT reviews on eham... http://www.eham.net/reviews/detail/7839
another option is a DIY frequency counter kit... BUT I would need to calibrate it...
Frequency Counter for VHF/UHF or test equipment
Frequency Counter
so which way should I go so I can align this unit and other like it in the future???
...and do NOT tell me to just take it in... I do this for fun... not to make money... well for the most part anyway
  #2
Old 12-26-2011, 09:27 AM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Get a scope for testing wave forms for aligning the VCO and PLL, as well as checking the modulation. You can use an o-scope as a freq counter; but they must be calibrated first. That will take time and $$$. But even a scope that hasn't been aligned should be capable of giving accurate wave forms.
As far as a freq counter goes, I would NOT chose either of the selections from those links. You need a test-grade type of counter. They can be had on eBay for $50-$100 used/new and will precisely what you demand of it without modifying or calibrating them.
Here is a fine example that should work quite well:
VC3165 Precision Frequency Counter Meter 0.01Hz~2.4GHz | eBay
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #3
Old 12-26-2011, 10:15 AM
mr_fx's Avatar
Senior Member
Default
thank you... I actually put a link to that unit as well
  #4
Old 12-26-2011, 02:10 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Using a scope to determine frequency is not very accurate at all. It will tell you if you are close but definitely not exactly what the frequency is regardless of calibration. This is because you must make a physical measurement of how many reticles the waveform occupies on the screen and multiply that by the sweep speed. Making a physical measurement means the result is dependent on human error, rounding off, and basically making a judgement call. There are accurate ways to use a scope to determine frequencies but they involve a two channel scope, a signal generator with accurate display of some sort and knowledge of Lissajous patterns.
__________________
Marriage is like a deck of cards. In the beginning all you need is two hearts and a diamond. By the end you wish you had a club and a spade.
  #5
Old 12-26-2011, 03:46 PM
359's Avatar
359 359 is offline
Senior Member
359 is on a distinguished road
Default
For $99, I just bought a Tektronix 2236 with freq counter and DVM. You have to be patient for the good deals, just place a low bid to lock out the BIN and let it ride. It may take a half dozen attempts over a period of weeks, but ask questions and bid on the right units. The last known calibration on this unit was 2-11, due 8-11. It had some dust and adhesive residue on it, but it cleaned up nice and checks out spot on.
__________________
"Contradictions do not exist. Whenever you think that you are facing a contradiction, check your premises. You will find that one of them is wrong."
- Ayn Rand (1905-1982)
  #6
Old 12-26-2011, 06:39 PM
2RT307's Avatar
Senior Member
2RT307 is on a distinguished road
Default
I leave a true alignment to a professional. But, when I have a simple transmit being off a bit, I use a known good radio that I use as a monitor while tuning the transmit VR to get as close as I can. Seems to work pretty darned good!
73,
RT307
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Using the Galaxy 959 frequency counter for PLL alignment? SD002 General CB Services Discussion 9 04-08-2011 07:26 PM
Uniden madison Wired To Texas Ranger FC-390 Frequency Counter ? Buckshot CB Radio Modifications 2 03-01-2011 09:16 PM
www.cbradiomagazine.com reviews the Dosy FC 50 frequency counter BOOTY MONSTER Meters, Mics & Other Accessories 18 08-11-2010 04:16 PM
Galaxy Saturn Freq Counter johnboy2729 Export Radios 2 03-12-2009 09:34 PM
Tram D201A Frequency Counter Nudget CB Band and CB Radios 0 04-12-2004 04:32 PM
Powered by vBulletin®
