12-26-2011, 01:41 PM
 | Extraterrestrial Admin | | Join Date: Apr 2005 Location: High Sierras Near Yosemite Nat Park
I doubt you will find a schematic for that one, they are a Basic 1 driving 4 amp.
The heat Led should only light when the heat sink is hot enough to trip the temp sensor ( this should also drop the relay out of transmit until it cools off) mounted inside.
One note of caution:
When removing the pop rivets that hold the cover on be careful not to allow the drill bit to damage the board, and when putting it back together, again, be careful, if the screws you use are too big around or to long, they will short the board to the case.......the mounting tabs are VERY close to traces on the board.
Good Luck.
__________________ Radio-active
NASA/SOHO there is no dark side in the moon, really. As a matter of fact it's all dark |
