03-07-2012, 01:40 PM
 | Yup | | Join Date: Dec 2008 Location: Silicon Valley CA, Storm Lake IA
Quote:
Originally Posted by ztothej Ok cool, what about the out put? how do I tune down the watts going in to the amp to a more suitable watt?
also my Modulation is set to 100% right now. | The radio output is set by L 10.
Adjust L 10 for 1 watt output - or even 1/2 watt output if it will adjust that low. That amp will work at 1/2 watt; so that is where I would set the radio output for that amp. It will sound cleaner and run cooler that way.
__________________ BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000. MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770. "...2 WR-011..." |
