Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
CB antenna for a scanner?
Like Tree5Likes
Reply
  #1
Old 04-28-2012, 09:02 PM
Senior Member
Location: Catskill mountains N.Y. Southern California native!
hammer0630 is on a distinguished road
Default CB antenna for a scanner?
OK I live in a apt. and have a 2 piece CB base antenna "Patriot 12' fiberglass" up as high as I could get it for my base station. Now I just purchased another scanner and would like an outside antenna though the land lord has not complained I feel a little funny putting up another antenna. My question is would I gain anything over the little attached scanner antenna if I used an antenna switch and tried to use my CB antenna to cover mainly the 400mhz UHF area" no 800 or trunked system here yet" for my scanner?
  #2
Old 04-28-2012, 09:57 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Try it. None of us knows just exactly how your situation would work with scanners, and experimenting is absolutely free. I'd guess that just about ANY outdoor antenna will perform rings around the usual POS that comes with just about ANY scanner.
gamegetter likes this.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
CWO4 USNR RET.
  #3
Old 04-29-2012, 02:00 AM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Yes it will work I have done it durring storms when I disconnect all my outside antennas
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #4
Old 04-29-2012, 06:47 AM
gamegetter's Avatar
Senior Member
gamegetter is on a distinguished road
Default it should work for you
all though i have not specifically tried that antenna, i have used my wilson 5k mag mount antenna before on my scanner in my car many times. I use an motorola adapter on the pl259 to plug into the scanner and it receives very good, much better than my homemade 1/4 wave mag mount i made for the scanner
give it a try you have only your efforts to put in and an adaptor at $4 bucks or so to buy unless you try to just rig it up somehow without a specific adaptor.
good luck and let us know how it works for you so others can learn.
  #5
Old 04-29-2012, 08:04 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Just for grins, find some small, unobtrusive looking wire. Tie a weight on the end of it and throw it on the roof (or over the roof). Stick the other end in the antenna jack. You might be surprised at how well that can work. How long? Beats me, it really isn't too critical, whatever length 'fits'.
Are you fairly close to a window? That window frame, or screen made from metal? That give you any ideas? If it will conduct electricity it can be used as an antenna. No, don't use the house wiring! At least not if it's 'hot'...
Robb and gamegetter like this.
  #6
Old 04-29-2012, 12:59 PM
Senior Member
9C1Driver is on a distinguished road
Default
The real problem I see is with that Patriot base antenna. I understand your situation but those were very poor antenna's.
  #7
Old 04-29-2012, 01:26 PM
Senior Member
Default
Yes I agree, even though I have not used another antenna since the 80's "got back into CB just a little while back" I feel that this Patriot antenna is my main down fall! I am looking at the new Star Duster M400. Thanks everyone for the input I am gonna look for a antenna switch and a BNC connector adapter.
  #8
Old 04-30-2012, 05:02 AM
Senior Member
The Jerk is an unknown quantity at this point
Default
I ran a wire dipole (horizontal) in my attic at my last place...it worked well on the 20-500 range. I ran a dipole because I was told it was still needed for even a scanner/receiver, and not just a transmitter...not sure how true that is or not?
I've also used a Wilson 5000 and a Hustler CB antenna for a scanner before, it worked better than having the antenna on the inside of the car.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Comet SMA-24 vs the Diamond SRJ77CA HT Antenna Robb HandiTalkies 11 07-16-2012 07:43 PM
Bearcat BCD396XT scanner antenna question 212Dan Tuners, Mics, Meters & other Accessories 4 03-01-2012 02:44 AM
WARNING, Don't Carry a Scanner into Michigan!!! Charger383 Scanning & Shortwave Listening 34 05-05-2011 11:24 AM
What is the best mobile radio scanner antenna? CB COBRA 148 GTL SSB AND Scanning & Shortwave Listening 5 10-17-2005 09:45 AM
Scanner Antenna Night Bandit Scanning & Shortwave Listening 2 08-11-2002 12:37 PM
Powered by vBulletin®
