Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Uniden PC68LTW
Reply
  #1
Old 08-27-2012, 08:40 AM
Junior Member
hollywoood is on a distinguished road
Default Uniden PC68LTW
Transmits, receives on weather but not on cb,.. any ideas???
  #2
Old 08-27-2012, 11:20 AM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
It better NOT transmit on the weather channels; that would make it illegal!
If it isn't transmitting on CB; the final transistor may have failed and will need replacement. This is usually caused if/when the antenna's SWR was not adjusted properly when installed. Newbee radio operators usually have this problem quite often. First radio?
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #3
Old 08-27-2012, 11:50 AM
Senior Member
Greatvalue1 is on a distinguished road
Default
Quote:
I think they were saying that the radio "Transmits on CB, and that it also receives the WX just fine, but that it is not receiving when it is in the AM CB mode".
If this is the case, then that sounds like a pretty funky problem. If the radio is new I would just return it.
  #4
Old 08-28-2012, 08:38 AM
Junior Member
Default
Robb,.. Greatvalve1 is correct, it transmits in cb mode but does not receive in cb mode, but receives weather in weather mode,...
It's not my radio it's a friends, I have some knowledge of cbs, although not to the degree most of you, (mostly learned by reading and some good people on here who have helped me),..
I did not realize the final could cause the receive issue since i had key up and tx, on the other hand the owner is a 'cover driver' and uses different trucks, he may have had one with a high swr and taken the final out,.. i'll look into that.
Thank you for your replies....
  #5
Old 08-28-2012, 09:59 AM
Senior Member
Default
Hollywood, How did you or your friend test the transmit?
This might help narrow down the problem.
  #6
Old 08-29-2012, 09:14 AM
Junior Member
Default
Greatvalue1, was told,.. my friend was running with another driver, talking away then nothing,.. called the other driver's cell phone and was informed he was answering him but my friend could not hear it. I hooked it up to a SWR/power meter saw it had dead key and swing never actually did a audio check myself. Hope that makes sense,...
Thank you!!
  #7
Old 08-29-2012, 11:49 AM
RatsoW8's Avatar
Supporting Member
RatsoW8 is on a distinguished road
Default
This is a funky issue. Unless he just has a switch in the wrong position it willprobably require someone to track down a bad component in the receive section. The radio probably has a seperate receive board/audio amp for the WX band which may be why it receives and CB doesn't. I bet it's a bad transistor somewhere in the audio chain.
__________________
Closet Biker, CB'er and snooty Ham!!
20 wpm Extra
  #8
Old 08-29-2012, 12:53 PM
Senior Member
Default
This issue needs a professional to find the problem.
If I had to guess though, I would say first look internally at the WX/CB switch to see if there are any unsoldered connections.
If the connections on the switch look fine then I would agree with RatsoW8.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Uniden - PC68LTW Bearcat Series 40-channel CB Radio with Weather Alert Ebay CB Radio Gear eBay Auctions Ending Soon 0 05-27-2012 11:10 PM
Cobra 2000 vs. Uniden Washington Master Chief CB Band and CB Radios 14 05-27-2012 06:02 PM
Ebay: Uniden PC68, TRC465, Uniden Pro710e wcsd106 CB Radio Gear SwapShop 1 12-12-2010 08:03 AM
Uniden PC68LTW questions. Foxx55 CB Band and CB Radios 1 08-08-2009 02:23 PM
Uniden BCD996T NorthStar Scanning & Shortwave Listening 12 07-07-2006 02:54 PM
Powered by vBulletin®
