WorldwideDX Amateur Radio Forums
WorldwideDX Amateur Radio Forums (http://www.worldwidedx.com/forums.php)
-   General CB Services Discussion (http://www.worldwidedx.com/general-cb-services-discussion/)
-   -   Viagra blue dot 'b' board problems (http://www.worldwidedx.com/general-cb-services-discussion/149430-viagra-blue-dot-b-board-problems.html)
Lil'Yeshua 12-10-2013 04:26 PM
Quote:
Originally Posted by m42duster (Post 454797)
Somebody smell smoke?
Noooooo!
I'm not about to do something without finding out first what I need to know. I've worked on $3000 car stereo installs enough to know that you don't hook things up wrong and not expect smoke. I was just thinking about me installing the LesCom board and then send it to DTB to dial it in. I'm asking questions. One thing i do want to do is buy another on/off volume pot for this radio and change out the talkback pot so that I can switch off the talkback.
Brake Weight 12-10-2013 04:31 PM
Once you let out the smoke, it can't be put back in. It's gone forever.
I had an electrician tell me that when he first got onto a ship that was all 220v with converters everywhere for the stupid Americans.
Lil'Yeshua 12-10-2013 04:33 PM
For the ones who don't know the Radio Shack sells converters
wavrider 12-10-2013 05:26 PM
Been a few years but I think the the anl nb filter switch plugs into the les comm board.
then this becomes your normal, then high/low ch switch.
there is detailed instructions on how to install included with every kit.
Even on his sight is instructions
Lester's Custom Truck Shop - Galaxy 959 Installation Instructions
Lil'Yeshua 12-10-2013 05:50 PM
Yeah,but it's going in a brand new Ranger TRE-936ffc which is similar to a 959 but instead of a slider switch it has a push button to switch the ANL/NB on. I can get another on/off volume switch and mount that where the mike gain is and use that for mic gain and switched a talkback volume switch. Get another three position S/RF,CAL,SWR switch,change out the talkback volume switch and use that as a band switch. Clip the roger beep leads and solder those together and use the roger beep push button switch for a 10 kc up switch.
Of course,as cheap as Copper is selling these 936's I could buy another and keep it stock.
P.S. I might get one for my 959 but I'll check for cold solder joints on the 959's Viagra board first and put a 10 ohm resistor where I have the R133 bypass jumper soldered in.
Just pondering.
Brake Weight 12-10-2013 05:53 PM
Quote:
I have two as well as many others, also. But US stuff is all 110 plugs, but you can charge just about all your electronics with 220 and a small adaptor. But there was always someone forgetting and turning the smoke loose with a shaver or something. Elec Tech smoked a big screen TV once.
m42duster 12-10-2013 06:57 PM
Silly foreigners and their goofy electrical outlets.
dave457 12-10-2013 07:00 PM
Why don't you just call him up and ask
Sent from my SGH-T599N using Tapatalk
Powered by vBulletin®
Worldwide Radio Forum
