Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
BBI amps, anyone heard of them?
Like Tree20Likes
Reply
  #9
Old 06-20-2013, 04:58 AM
Senior Member
Shockwave will become famous soon enough
Default
You can tell by the way it was carefully placed a quarter inch from falling off the shelf to make it in the picture that it's probably a dud. The 8877 can easily be converted into a paperweight. Feed the cathode without raising the filament above RF ground or over dissipate the grid and say bye bye. It's got plenty of gain to destroy itself if misused or if Eimac is having a bad decade like the 1980's when they sold thousands of defective 8877 tubes.
  #10
Old 08-28-2013, 03:49 PM
Junior Member
Mr BBi is on a distinguished road
Default
Well here this should help. this is from when I tested the amp, back when I built it.
m42duster and Z-MAN 369 like this.
  #11
Old 08-28-2013, 08:30 PM
Senior Member
9C1Driver is on a distinguished road
Default
When you come up with a nice regulated class AB amp you will be on to something. A good AB amp is hard to find these days.
  #12
Old 08-28-2013, 08:54 PM
Senior Member
dxhound is on a distinguished road
Default
I would like to see a DC current meter, voltage meter and power meter all in one shot. That will be the true test of linearity and performance. A Spectrum analyzer shot out to the 5th would be nice as well.
n0zna likes this.
  #13
Old 08-28-2013, 09:18 PM
Junior Member
Default
I have built in class "b" and ab1,ab2 and 1a. but I do it all here is a Ameritron I did about a month ago for a guy in spain. I built a nice little 4cx350b box this last weekend. anyways u all have a nice night
n0zna and m42duster like this.
  #14
Old 08-28-2013, 10:24 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Quote:
I am quite familiar with class a, ab1, ab2, b, and c but what is class 1a?
__________________
Marriage is like a deck of cards. In the beginning all you need is two hearts and a diamond. By the end you wish you had a club and a spade.
  #15
Old 08-29-2013, 02:11 AM
Junior Member
Default
good point... what is 1a? lol a1 is what i was talking about..
  #16
Old 08-29-2013, 08:18 AM
Senior Member
Default
Will you be able to post a vid with current draw, voltage and power meter measurements?
Also in your video you mentioned "with this technology" What are you doing that is different from other builders? Using pad on input to present a 50ohm resistive load? High quality input transformers?
PS, I def. like the compact design and fan arrangement. Im also surprised you dont have any tuning issues with the transformers in that close of proximity to some rather substantial metal. I just wonder if the fans will dissipate enough heat. That also depends on the efficiency, hence my interest in volt and current readings.
n0zna likes this.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
WANTED: CHEAP AMPS, dead or alive... RM Italy, Palomar, & any other junk you have! mr_fx CB Radio Gear SwapShop 1 03-12-2012 02:02 AM
What are Amplifier Classes? TonyV225 Amplifiers 19 06-18-2011 07:25 PM
Solid State Amps, Classes, Cleanliness.. eagle1911 Amplifiers 8 02-08-2011 08:55 PM
a few stupid questions about tube amps BOOTY MONSTER Amplifiers 9 05-16-2009 04:16 PM
SNOWCAP AMPS ? Switch Kit Announcements & Open Forum 16 01-05-2006 06:14 PM
Powered by vBulletin®
