Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Lafayete Telsat SSB-100 23 channel
Reply
  #1
Old 11-08-2003, 05:39 PM
Triple J is on a distinguished road
Default Re: Lafayete Telsat SSB-100 23 channel
I'm not exactly sure what you need to do besides the information directly out of the owners manual for Alignment procedures. You may be able to find the correct Variable Resisters to make your adjustments with this information.
Here is the 27 MHz Transmitter Stage Adjustment.
1. Connect a RF Wattmeter (50 ohm) to the antenna connector
2. Connect the oscilloscope or RF VTVM across the antenna connector
3. Place the channel selector in 13 CH position.
4. Set the transceiver into transmit mode
5. Place the mode switch in USB position
6. Apply 2.4 KHz, 10mV audio signal to the microphone input circuit.
7. Temporarily place the RV 1, RV 2 and RV 8 in their center position
8. Adjust L2, L3, L4, L6 and L7 for maximum amplitude of scope display or maximum reading on the VTVM.
9. Rotate the channel selector and make sure that the amplitude of the scope display or the reading on the VTVM at each channel in almost the same. If an excessive difference is observed, readjust L2 and L3.
10. Next, adjust the RV 5 and L6 to obtain RF output of 11W on the wattmeter.
11. Apply two signals (500 Hz & 2.4 KHz) of 5mV to the Microphone input circuit and adjust RV1 and RV2 so that scope display as shown in fig 3B is obtained. (wave is sort of narrow with no flat-topping)
12. If the scope display shown in Fig 3C (Flat-topping) is obtained, adjust RV 8 for scope display of Fig. 3B.
13. Next, measure RF output voltage at the antenna connector with 2.4 KHz modulating signal (5mv) applied to the Mic input circuit and note the value.
14. Next, measure the output with no modulating signal applied to the MIC circuit and read the RF output voltage. This value should be lower than 40 dB from the value obtained in the sep 13. If not, adjust RV 4 and TC2.
Here is the AM Transmitter Stage Adjustment
1. Connect wattmeter (50ohm) to the antenna connector on the rear panel.
2. Also connect the oscilloscope across the antenna connector.
4. Place the mode switch in AM position and set the transceiver into transmit mode.
5. Adjust RV 607 so that the wattmeter indicates 3.8W.
6. RF Meter Adjustment: Make sure the RF meter pointer indicate 3.8W. If not, adjust RV 401 to obtain the reading of 3.8W.
7. Next, apply 2.5 khz, 7mV audio signal to the microphone input circuit and adjust RV 7 to obtain 90% modulation.
I sure hope this helps. Mine was modded by a shop for my Dad about 26 or 27 years ago and still sounds great, I don't dare to take the cover off and mess with it.
Jim
CDX-311
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=tr iplej@worldwidecbradioclub>Triple J</A> at: 11/8/03 6:07 pm
__________________
CDX-311
  #2
Jim
CDX-311
__________________
CDX-311
  #3
Old 11-09-2003, 08:53 PM
generalelectricman
Guest
Posts: n/a
Default Lafayete Telsat SSB-100 23 channel
I have a Lafayette Telsat SSB-100 23 channel home base with a Astatic D-104 desk top power mic i want to turn up the modulation inside the radio and turn up the wattage to as much as i can with this radio if anyone cam help me please tell me the information would be very appreicated
you can e-mail me this information at theman17234@aol.com
</p>
  #4
generalelectricman
Guest
Posts: n/a
</p>
  #5
Old 05-06-2012, 05:55 PM
K9FON
Zman is on a distinguished road
Default
Dont expect a lot out of one of these as it falls under the old lower power rules before everything went to 40 CH.
  #6
Old 02-28-2013, 02:56 PM
Senior Member
15minigrass is on a distinguished road
Default
I know this post is old. But how can i re-align the frequency. When I TX on chan 11, it comes out on chan 10.
__________________
Mobile:
Prez Grant Export/Stock Mic
Black Widow 350V
Two 9" Predator 10K
RS SWR/Watt Meter
Base:
P/T COBRA 146GTL(Spare)
President Jackson
Turner +3 Hand Mic
Pyramid 25 Amp P.S.
Home Made Ground Plane Base ant.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
