Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
eagle 515
Reply
  #1
Old 07-17-2005, 08:02 PM
shoemaker is on a distinguished road
Default eagle 515
Hello guys, can I get some info on this tube amp. Max watts. tubes and how much drive it can take? Is there a web site?
  #2
Old 07-18-2005, 06:19 PM
Senior Member
paws264 is an unknown quantity at this point
Default Re: eagle 515
Quote:
The Kenrich "Golden Eagle" line (Eagle 400, Eagle 500 and Eagle 515) were all basically the same, they consist of 2 X 20LF6 driving 5 X 20LF6 in the stock configuration. With a 4 watt radio, it will peak at about 400-500 watts however, if you install a pre-driver tube (6KV6A or the likes) the amp would do 750 watts dead key and would swing upwards from there.
You can put a hi-power export radio in front of the amp if it has not been modified with the pre-driver.
Look for KENRICH
  #3
Old 07-23-2005, 08:11 AM
Default
Paws thanks for the info, will look it up. :x :x :x
  #4
Old 10-17-2005, 05:43 PM
Senior Member
sleepwalker is on a distinguished road
Default
what is one worth in very good condition
  #5
Old 11-08-2005, 01:23 PM
Default
Does this amp splatter and cause tvi?
  #6
Old 11-08-2005, 03:01 PM
Registered User
FL Native is on a distinguished road
Default
depends on radio - dirty in = amplified dirty out
  #7
Old 11-08-2005, 03:10 PM
Default
zacheryT or hr2510. What about a pre amp, how much drive to put in it?
  #8
Old 11-11-2005, 01:05 AM
Senior Member
mrcoily is on a distinguished road
Howdy,,i ran i 525 eagle for many years, mine did an easy 800 watts out,i hit mine with an 2000gtl 2-18 watts input,,and the amp would swing 200-800 ran it that way for 2 years..should have never sold it VERY NICE AMP onr of the better ones,,i sold mine for 400 bucks,,,and the guy ran it at high dead key 500 watts and smoked the transformer :x what a waste,,if you get it keep the dead key down around 200 watts and let it swing and it will run for years ..Dan
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
