Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
KLB-300 Amplifier Overhaul (2x 2sc2879's)
Reply
  #1
Old 11-29-2005, 08:53 PM
Junior Member
mrblue630 is on a distinguished road
Default KLB-300 Amplifier Overhaul (2x 2sc2879's)
G'day Folks....
A few months ago i picked up a KLB-300 amp. The KLB amps were manufactured in Japan and were sold here in Australia back in the late 80's early 90's. Models include: KLB-110DX, KLB-240DX, KLB-300 and a CVS-450 UHF amp. These are models that i am aware of.
This particular amp i purchased was in fairly good condition for it's age. Besides the meter being pushed in, everything else was in good working order.
I fired the amp up into a 50 ohm dummyload and found that the input swr was high, and went up higher when i flicked the amp to Hi power setting.
Output power was; 3watt D/K from radio, amp 50w swinging to 100w AM and to around 160w SSB, on a Bird 43 meter with a 250H slug @14v.
Upon removing the cover i immediately found a few things that needed to be done to get this amp running to it's full potential.
Here is a list of things that are needed or need re-doing.
* The power lead; Lacking current capabilities and the cable itself was connected to the on/off switch. The on/off switch used in this amp is a standard miniture toggle switch rated at 2 amps. So thats approx 30amps of current going through a 2 amps switch...... :?
* No Negative Feedback.
* Hi/Lo switch affects input SWR....it's gotta go.
* Hi/Lo input drive switch, Again affects input SWR...gotta go
* No Regulator to control Bias Voltage.
* Bias Voltage too low, need to replace bias resistor.
* No Relay to switch Bias when TX & RX
* Thermal Tracking diode. In this amp the diode is under the pc board touching the heatsink, this is ok but could be better.
* All tunning caps, collector/emitter caps to be replaced with new Silver Mica Caps.
* Input and Output Transformers (cores) to be rewound with new Teflon wire.
This is a schematic of the bias circuit used in this KLB300, mods included (Reg, Relay, Resistors etc....)
Most of you could easily incorporate this bias circuit into their own 2 pill 2879 class C amp
  #2
Old 12-12-2005, 03:40 AM
Junior Member
Default
Thanks Greg,
I am currently moving house so i will post all the rest of the info on this amp when i settled.
Just to let you all know though, i got this amp set up in the mobile at the moment and it's kicking ass!
  #3
Old 12-12-2005, 05:36 PM
Senior Member
bob85 is on a distinguished road
Default
nice job blue, where are the pictures?
__________________
tom bearden taught me that quantum entanglement allows thought to travell faster than the speed of light, this explains why at first you can think somebody is smart but if you wait a while you will see they are not very bright at all.
  #4
Old 12-14-2005, 10:15 AM
Moleculo has disabled reputation
Default
Webshots doesn't seem to like it if you link to their site, so I put the images in the Forum photo album.
  #5
Old 12-16-2005, 03:44 PM
guardian of freedom
rfoverlord is on a distinguished road
Default
tnx blue, for helping to further educate some of us so that we may enjoy our hobby a little more. 73
__________________
If you run, you'll only die tired.
CDX-251,2SF251,AE926, N9MSH
  #6
Old 11-14-2010, 02:47 AM
43WR30
Rb30 is on a distinguished road
Default
Sorry to bring back an old thread but I have a klb-400 which has the same design as the klb-300 with 2x 2sc2879's. About 2 years ago I started modifying this amp with the diagrams and pics on this thread but family stuff came along and the project took the top shelf untill now. However I see that all the pics have gone from this thread and I looked on the home page for a photo album that Moleculo mentioned however I can not find it. Any help??
WR30 (VK2DXN)
vk2dxn@gmail.com
  #7
Old 11-14-2010, 01:44 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Quote:
WR30 (VK2DXN)
vk2dxn@gmail.com
mrblue630 mrblue630 is offline
Junior Member
Last Activity: 02-13-2007 02:19 AM
  #8
Old 11-15-2010, 02:58 AM
43WR30
Default
Quote:
Junior Member
Ok I have found the pics on another site so all is good, oh and btw Mack thanks for stating the obvious there captain
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
