Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Uniden President HR-2510 or HR-2600
Reply
  #1
Old 01-04-2006, 05:59 AM
Junior Member
225inthegreatlakes is on a distinguished road
Default Uniden President HR-2510 or HR-2600
Im not sure if this is the right area to post this question or not but I was wondering if there was any diffrence between a hr-2510 and a hr-2600.what is the diffrences and which one is the better radio?
  #2
Old 01-04-2006, 08:18 AM
C2's Avatar
C2 C2 is offline
Senior Member
C2 is on a distinguished road
Default
the 2600 has a different cpu, which makes it not possible to simply mod for 11-meters. It also has CTCSS and split freq operation.
the 2600 is better with the chipswitch mod because of that.
But overall, they are basically the same, with probably a few other minor differences I have not thought of.
  #3
Old 01-05-2006, 07:21 AM
Junior Member
Default
ok thanks for the reply back, I have a chance to get a 2510 or 2600 and was told about the chipswitch deal.I was just wondering which one I should invest in and have the chipswitch and mods done to it.
  #4
Old 01-05-2006, 10:41 AM
EDUK8TR's Avatar
EDUK8TR is on a distinguished road
Default
C2 is right. If given a choice I would go with the 2600 and have it chip-switched to access 11m. I like the fact that I can dial in a different freq for each individual band (0-4) and use it like a memory. That gives me 5 freq.s that I use most often that I can access quickly by just pushing the band button to rotate thru. Makes it quick and easy while on the road. There are a number of different mods that can be done. Which ones you want would be up to you. Personally I had the RIT, variable power mods and the finals changed out in mine. I have a 2510 that is not chipswitched but has the same mods and keep it as a backup radio.
73's!!
Wayne C.
__________________
"To be is to do"-Socrates;
"To do is to be"-Sartre;
"Do Be Do Be Do"-Sinatra;
WV4L,CDX-787,AK2787
Mobile/Base
Icom70000/Kenwood TS-2000 w/LDG AT-1000ProII
Stock mic or W2ENY headset on VOX/D104 w/Heil HC-5 or W2ENY headset on VOX
Tarheel 200A-HP w/N2VZ Turbo Tuner,Larson NMO 2/70B/TX-472 tower w/ 80M Horizontal Delta Loop, 20-6M K4KIO Hex beam, Gulf Alpha Dual Band Cross Polarity 7X7El. 2M:10 El.v70 CM beam, Arrow 146-440GP
Ameritron AL80A
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
