Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
tuning cobra 2000 gtl
Reply
  #1
Old 04-15-2006, 06:12 PM
excavator701 is on a distinguished road
Default tuning cobra 2000 gtl
i just aquired a 2000 gtl i know the am carrier is vr10 and modulation is cut 131 but what adjust the pep rf output can anybody help please
  #2
Old 04-15-2006, 08:59 PM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
sure thing ,but do yourself a favor and dont cut r131 , you don't need to do a lot for those radio to sound awesome , Modulation to 100% is all you really need on those which is VR12 /AMpower is VR10 /and SSB power is VR11
  #3
Old 04-16-2006, 07:31 AM
Senior Member
Thestonerguy is on a distinguished road
Default Re: tuning cobra 2000 gtl
Quote:
The 2000 will sound great with an amplified mike like the Turner Plus3. Please don't cut the limiter....
__________________
  #4
Old 04-24-2006, 07:16 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
dont cut anything alot of times it makes your sideband or modulation uncontrolably wide open heres what you need....VR7 AM MODULATION set this at 100%....VR11 SIDEBAND RF POWER generally they hit about 22-23 watts just set to 20 watts....VR10 AM RF POWER you need to watch this setting some of those power supplies were weak or just enough to run the radio even the sideband at 20 watts will draw on that power supply watch for lights dimming. if you see light drastically dim then best thing to do if you insist the higher power output is to run that radio on an external power supply a 6-10 ampre is plenty and very reasonably priced and the radio will run smoother at pep .you may also see and hear the rf power meter slamming the fullscale side after turning power settings up to avoid trashing that meter adjust VR6 for a safe fullscale reading.. These should get you going on the right track if you need any frequency adjustments just post it here and ill help but i dont suggest messing with any vco's or cans unless you have the propper equipment or are absolutely sure about what you are doing
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #5
Old 04-28-2006, 04:59 AM
Default cobra 2000 tuning
i appreciate thge help my question is i am only getting 15w pep is there some thing in the radio to adjudt for max pep the only info i can get on the net is what i posted cant find nothing for pep adjustment
thanks again!!!!!!!!!
  #6
Old 04-28-2006, 08:14 AM
Switch Kit's Avatar
Senior Member
Default
What kind of meter are you using ? and is that off a dummy load or the antenna ? 15 watts pep on AM for that radio is not far off course , should do 18 to 20 on SSB ,don't under estimate that 2000 , as I said before ,they don't need very much done to them for them to perform well .
  #7
Old 04-29-2006, 10:00 AM
Default cobra2000gtl tuning
i undrstand all that and i appreciate the help but is there a pot in the radio that can be turning for max pep??????????
  #8
Old 04-29-2006, 10:01 AM
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
