Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
galaxy 959
Reply
  #1
Old 09-17-2006, 02:51 AM
pat pat is offline
Junior Member
pat is on a distinguished road
Default galaxy 959
hi need help. question ? galaxy 959. if i turn vr16 i get an increase in modulation? am i correct? Is this ok to do? also how much can i turn it? is it really that easy. thank you. pat
  #2
Old 09-17-2006, 07:25 AM
broncoman529's Avatar
Senior Member
broncoman529 is on a distinguished road
Default
Quote:
Originally Posted by Pyra Ted
Just turn it all the way to the right like everone else does.
Just have it done by someone that knows what they are doing. People who give advice like that are the ones who destroy radios. :roll:
__________________
Larry T. CDX529
" The Littlest Station In The Nation!"
  #3
Old 09-18-2006, 02:03 AM
pat pat is offline
Junior Member
Default galaxy 959
hi again. yes i'm new to this. but i want to learn. want to do some mod myself if not to complicated. help.
  #4
Old 09-19-2006, 05:53 AM
Senior Member
Default
Don't mislead the fella with that someone who knows what they are doing crap.
He knows what pot to turn let him turn it.
Mislead him? Misleading someone is having a person who does not know much about radios turning random pots. The reason I give that advice to people is because I have been on the bad side of people being inside a radio, It has cost me a lot of money over the years to fix peoples screw ups. I have the knowledge to replace components that fail, But I do not have the correct equipment to peak and tune or align a radio properly so I leave it to someone who knows what they are doing. If you want to teach him that is fine, But to tell him to just turn the pot all the way to the right is the wrong advice. By turning that all the way in any direction can easily overload the circuit and do damage. I say use the proper equipment and don't risk damage to the radio.
__________________
Larry T. CDX529
  #5
Old 09-20-2006, 12:57 AM
pat pat is offline
Junior Member
Default galaxy 959
hi again. i still would like to learn. have to start somewhere. i have a little now how. maybe just enough mess something up. but still would like to try something simple and go from there. would like to add extra channels to my 959. went to cb tricks and looked at the mod seems simple enough. 2 switches spliced between 2 wires. am i right or not ? if it is not tell me. would there be anything to do after this. maybe an alignment? would there be anything else?
  #6
Old 09-20-2006, 06:40 AM
Senior Member
Default
I would repost your questions in the CB Radio part of this forum, It seems to me that not very many people look at the Tech Bench area to much. You will probably get more correct information there. As far as online modifications go, Some are correct and some are not. If I remember correctly after any channel modification an alignment should be done on both receive and transmit. A signal generator is needed for the receive side of the alignment. So go repost in CB RADIO and I am sure a bunch of people will jump in to help you learn. Hope this helps.
__________________
Larry T. CDX529
  #7
Old 09-21-2006, 06:39 AM
Senior Member
Default
You have no idea what you are talking about.
Do you care to explain?
I have not once seen you add one piece of information that would be relevant to this person's question.
Is certainly the "HACK" way of doing things!
So Mr. Intelligence please explain to me what it is you think I don't know what I am talking about.
__________________
Larry T. CDX529
  #8
Old 09-21-2006, 09:35 PM
Senior Member
Default
Boy, It's funny how Doc's electronics does most of the work on my radios and never turns the pot all the way to the right...Oh wait a minute he must be the 1% of shops that don't....Oh and DTB Radio, He didn't turn the modulation pot all the way to the right on my Realistic TRC-448(He must be part of that 1% that doesn't either!). I am done talking to you!!!
__________________
Larry T. CDX529
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
