Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Top Gun Modulator
Like Tree5Likes
Reply
  #1
Old 09-28-2006, 10:05 AM
Senior Member
DTB Radio is on a distinguished road
Default Top Gun Modulator
I'm posting this to see if we can get some good technical discussion going of this somewhat controversial modification/module. I've done a bit more study recently, and here's what I've found:
The top two photos are from a magnum S9, tuned to exactly the 4:1 ratio, full power, 100% modulation. The first two photos are without the Top Gun, the second 2 are with the Top Gun. The photos will speak for themselves to you fellow techies, so I won't go into detail on what's shown. I will note that NO settings were changes on either the 'scope or analyzer during the test, other than center position on the analyzer (to keep the signal roughly centered on the screen). The photos with Top Gun on show increased audio harmonic distortion, which is showing up as a "clipped" audio signal in the scope photo, and as a much wider sideband (and much higher IMD) in the analyzer photos. No gain in the usable sidebands is seen. I ran the same tests with the radio set for about 2 watts key, and basically the Top Gun just seems to artificially turn the radio up to full power while modulation is present, then let it fall back to the 2-watt key level when modulation is not present. I didn't bother to post those photos because the TG photos at 2-watt key are all but identical to the high-power photos without the TG.
Before Top Gun:
After Top Gun
Now before everyone and his brother starts posting lots of opinions based on just using their radio, let me say that I'm not looking for non-tech postings on this one. I want to hear input from actual techs with experience in testing radios with the TG feature either built-in or added, and hear what their test results were. Also, I understand that most power meter shows more power with the TG than without, but the photos above show that there isn't any more power developed. I want to hear from any techs who actually have seen more power developed on an analyzer and 'scope, as well as those who have basically seen the same thing I have.
__________________
73's as always!
SHOP AT DTBRADIO.COM'S ONLINE STORE
Use this email address to contact me.
  #2
Old 09-28-2006, 10:45 AM
Senior Member
Location: 6000 feet above the Mojave Desert, Tehachapi, Ca
Toll_Free is on a distinguished road
Default Re: Top Gun Modulator
Quote:
I can't comment on TOP GUN, but ARF had a modulator built into their ARF2001 that seems about the same.
Increases the apparent modulation on AM... We all know how that is accomplished (read distortion)... On SSB, it might do something.
If the manufacturers want real processing, they need to either process the RF, and use it to control the feedback in the audio circuit, or convert the audio to RF, and apply RF clipping at that level, then reconvert to audio.
Suffice to say, neither is cheap, nor will it find it's way to CB.... At least, not since the 70s
--Toll_Free
TonyV225 likes this.
  #3
Old 09-28-2006, 10:37 PM
Moleculo has disabled reputation
Default
DTB, I have the scope, but not the spec analyzer. If you send me a spec analyzer I can test out the top gun and post my pics, too
  #4
Old 10-10-2006, 09:27 AM
Senior Member
Default
I'm waiting (patiently?) for the prototype to be ready.
__________________
73's as always!
  #5
Old 10-11-2006, 12:06 PM
Senior Member
Default
Quote:
Originally Posted by JustinDePolis
Toll Free, not to hijack the thread, but I think it would be easy to do this properly. Even something like a couple diodes, an OP-AMP, and a audio bandpass filter could do the job, and proper feedback using a well designed AMC circuit. Sure, it's not the best way, but it would be better than anything out there right now, do you agree.
<<snip>>
I agree 100 percent. I think the secret to doing this is to use high speed diodes... Remember, we are using this to control an audio frequency amp, but rectifying it at the RF level, so those diodes should be able to switch at the frequency of the carrier..... Sidebands (we hope) aren't +/- megaherts I think a couple years back we all learned this with bias schemes.
Anything that will increase the avg modulation will be a boon to CBers... Of course, clipping (like Lou's circuit does) does a good job (I just think his needs more drive on the output)... But sample it at RF, and you're actually helping the transmitted signal, not shaping the input to the modulator based upon a predetermined level the original engineers designed into the radio...... (this would help when moving the carrier control around A LOT.... Your processor would let you set a modulation level, instead of audio input level like the mic gain does now.... Whereever you put your carrier, the modulation will track, and the amount of "processing" you set should never change with different carrier levels.....)
Anywho.. Ima stfu now. Thread hijack over
--Eye Uh Toll Uh
  #6
Old 10-11-2006, 12:07 PM
Senior Member
Default
Quote:
Originally Posted by Jericho Willie
I want to post something here but I'm not sure what your definition of a Tech is? Do I need a degree in RF Engineering or would that over qualify me?
I've found that a technician is usually the one that makes the engineers prototype work in the first place.
Go read rec.radio.cb and search my posts for some of my signature lines related to Engineers...
--Toll_Free
  #7
Old 10-11-2006, 01:44 PM
Senior Member
bob85 is on a distinguished road
Default
i have built a bunch of processors/clippers over the years mainly from discrete components but even a few vogad chips have been tried,
for me by far the most effective was rf clipping,
more expensive to do yes but if you use a decent bandwidth filter and set it up correctly i think they work great and tend to sound sweeter and clearer than the typical compressed nasal sound of most simple audio based compressors even when running relatively high levels of compression,
to my ears no audio based compressor i ever heared comes close to a well setup rf clipper if your main concern is to be heared and understood under the most difficult conditions,
want to bust a pileup hit the 18db button on the datong and punch a hole in the woollybacks muffling away on the ft1000 subwoofers and most important is that all the subwoofers hear your only using an old ft7 with a modified cb amplifier
__________________
tom bearden taught me that quantum entanglement allows thought to travell faster than the speed of light, this explains why at first you can think somebody is smart but if you wait a while you will see they are not very bright at all.
  #8
Old 10-13-2006, 07:53 AM
ss8541 is on a distinguished road
Default pics not displaying
is anyone else having a problem with the pics not displaying in this topic? i have viewed it 3 different times over the last week and have not had one pic load yet.
__________________
Richard Byrd
8541 Electronics
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/general-cb-services-discussion/24464-top-gun-modulator.html
Posted By For Type Date Hits
Tuning President Walker i JMC Supercom 400 - CB-MANIA This thread Refback 01-04-2010 06:01 AM 1
Tuning President Walker i JMC Supercom 400 - CB-MANIA This thread Refback 12-31-2009 12:54 AM 1
Tuning President Walker i JMC Supercom 400 - CB-MANIA This thread Refback 12-30-2009 10:26 PM 1
Tuning President Walker i JMC Supercom 400 - CB-MANIA This thread Refback 12-30-2009 03:07 PM 55
Powered by vBulletin®
