Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Lords homebrew Cubical Quad+1 antenna. 5 element
Reply
  #1
Old 04-01-2007, 08:17 AM
Senior Member
lords is on a distinguished road
Default Lords homebrew Cubical Quad+1 antenna. 5 element
My Home Brew Cubical Quad+1 antenna 5 element made back in feb 11 1999
The spacing of each element is tuned for freq length.
and all 3 directors are the same size.
the driven of course is the Second one from the back from the center point of the mast..
I know its only 1 picture and hard to see the cubed copper around the elements..
The outer part of the elements were made red/orange 8 foot from garden stakes.
I guess they were some kinda of heavy duty fiber plastic,they worked at the time.
The boom was 1 1/2 inch round and was 34.5 foot long and a bear to work with.
each element was spaced almost 7 foot apart from each other give or take a few inches for fine tuning..
the reflector element whole length was 34 foot, and for the rest of the elements,Driven,director 1,2,3 take about 1 foot off going down to director 1 ,which is the front of the quad beam..
now in order to keep the SWR low this antenna didn't have a matcher it was the length of the outer cubed copper wire.
put it this way just the wire on 1 side of the cube was 113.5 ,inches(9foot 5inches) so taking standard coax,black RG58 50ohm unbalanced and ataching it to the balanced corner of the
driven wasn't bad seeing though I did the math and made the quad centered for 27.2050(good old channel 20) my SWR was at 1.2 which wasnt bad..
The worst part about this whole thing..and i mean in a bad way
I did this all myself, besides having a buddy stretch out the 200 foot of copper wire with me with his truck and a eye ring mounted to the side of a barn...
the second worst part was keeping the copper straight well making the 9.5 foot bends for the cube!
I never did see how heavy this thing was but it was a bitch putting it up for a 1 person job..it was up for about 3 years before it got sold.
That 100watt box I was talking out of had no problem talking anywhere I swung that quad to as you know the gain on any beam is sweet!
The rejection..well the hole backside of the antenna was one..
a good friend 5 miles from me had no problem watching me go from 30+ to about 1 on his meter when i swung that sucker away from him...
it was under 100 bucks to build ..less rotor that was 300 bucks with a bearing.. I had that rotor untill 1 week ago with a bearing
some MotherF$%#er stole it off my porch..1999-2007 RIP rotor
Thanks for looking
Until next time when lords puts up his Spitfire 427 3 element beam
with a 25 foot Reflector for starters..
Peace!
__________________
Cobra-90LTD 8 swinging 35 Noclip
Cobra 148GTL
Cobra 148F(EXPORT)
Cobra 200GTL
Mod V-Plus
Homemade 8 pill running 18 volts
Brute force 350
Maco V5000
  #2
Old 04-01-2007, 06:10 PM
Senior Member
fatdude1 is on a distinguished road
Default
very nice dude you know you are going to miss that 5 element and wind up maken a nother one
__________________
#1 mobile
Clear Channel AR-3300 100watt
Wilson 5000 RM
Tuner RK56
Alinco DR110
larson m150
#2 Mobile
Magnum S980
d104m6b
Turner RK 56
Wilson 1000 Mag
CDX421
  #3
Old 04-01-2007, 06:24 PM
Senior Member
Default
yep Ican feel it coming. I am on a 2 story building now with a nice big flat roof..
to top it off, I am above H&R block gov tax service :P
but I troubleshoot there servers ..so all is good..
this next one will be bigger
__________________
Cobra 148GTL
Cobra 148F(EXPORT)
Cobra 200GTL
Mod V-Plus
Brute force 350
Maco V5000
  #4
Old 04-04-2007, 08:34 PM
smokercraft is on a distinguished road
Default quad
Nice looking quad,but I have to question your reflector total length which you said was 34ft.I figured this twice and ran a java script program and it keeps coming up your reflector should be 37.860 at 27.205. The driven element comes out to 36.941. Am I reading your post wrong or did you have the reflector total length smaller than your driven element total length? Also you said the total boom length was around 34 feet, I don't see any type of truss system.Was wondering what was the wall thickness of that inch and a half boom?
  #5
Old 04-04-2007, 09:25 PM
Senior Member
Default
back then there was no java for this measurement..
34'33'32'31'30
it wasn't set for channel 20...and it was a water pipe.
remember the elements don't weigh much .there not full Aluminum.
thanks for looking
__________________
Cobra 148GTL
Cobra 148F(EXPORT)
Cobra 200GTL
Mod V-Plus
Brute force 350
Maco V5000
  #6
Old 04-04-2007, 10:21 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
If the Driven loop was 33 foot (396") it was cut for somewere around 30.500 Mhz.
113.5" per side (454") is much closer ( 26.560Mhz if this is the driven loop) to Ch 20 than the 34/33/32/31 foot number you posted above, sure you did not make a mistake somewere?
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/eit_171/512/latest.jpg
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #7
Old 04-05-2007, 12:53 AM
Senior Member
Default
well it was back in feb 11 1999.
but I do have it jotted down on the back of the picture.
hm ,maybe thats why the SWR was kinda high 1.7 on 20
now I see what happened It was in 26 instead of 27 :lol
and I was using a Antenna matcher..
back then didn't use java..didn't even know the net did the calc!
__________________
Cobra 148GTL
Cobra 148F(EXPORT)
Cobra 200GTL
Mod V-Plus
Brute force 350
Maco V5000
  #8
Old 04-05-2007, 04:27 AM
Default
driven wasn't bad seeing though I did the math and made the quad centered for 27.2050(good old channel 20) my SWR was at 1.2 which wasnt bad.. If your antenna was cut as you say it was,34,33,32,31,30 then that antenna was cut to 30.294 mhz, not exact but close.I would like to see the total wire length that you have jotted down on the back of the picture.And I figured your antenna with a pencil and paper the first two times,I used the java script the third time just to check myself.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
