Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
cobra 29 low dead key
Reply
  #1
Old 08-07-2007, 06:08 AM
Senior Member
fnkycoldmedina is on a distinguished road
Default cobra 29 low dead key
a friend brought this front mic cobra 29 over for me to buy .befor i buy it i need to find out what was done and reverse it .this radio only keys 2 watts and i need more .swings 16 or so but the key is too low for me .looking inside i see something that doesnt look factory on d17.....one leg of the diode was lifted and a resistor added to it .could this be the low key problem?thats all i see on that side .lets look on the solder side now.there is a black wire jumper going from the ground leg of l21(a dual core double can)to the leg of c105...whats this?is it there from factory?anybody got a picture of the solder side of a front mic 29?if you do send to "joe3857@aol.com"same goes for the component side if you have ,thanks.
  #2
Old 08-07-2007, 06:09 AM
Senior Member
Default
i went ahead and removed the resistor added to d17 but this did not bring the dead key back up.this radio has been clipped as well and even though it has you must speak into the power mic pretty loud to get it to swing.it sounds loud over my monitor radio and the talkback but being clipped you should get full swing with a whisper.this radio has 1969 final too.
  #3
Old 08-07-2007, 07:02 AM
Guest
Master Chief is an unknown quantity at this point
Default
Generally, you want a low dead key and swing up from there. Why do you need a higher dead key?
  #4
Old 08-07-2007, 07:08 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
sounds like the radio was set up to drive a texas star 2 or 4 pill or something with similar drive requirements .or maybe a larger amp with a built in driver .
  #5
Old 08-07-2007, 08:06 AM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
Quote:
He just wants a tuned radio ,which a 29 should do roughly 5 to 6 watt DK with anywhere from 20 to 30 watt pep swing ,especially if this radio carriers a 1969 final. (Even though there's a little more to it then just adding the 1969 to this radio.) What it sounds like he has here is a hack job which he would like to put back as close as he can get to normal operations. There's also NO need for the audio limitier in this radio to be clipped !! VR 4 should adjust to all the audio one would need on these radios. The low dead key "should already" give this radio off the scale audio as long as vr 4 has not been adjusted , (he said he was having problems with the audio as well) he is saying that the DK can not be adjusted from the 2 watts , this means there's something inline that is locking the DK in place ? kind of like a swing kit mod that will also lock the DK in place but yet still give the pep swing from the lower DK , from what FNKY is trying to say here , there are many variables to look at to figure out what's really going on with this radio.For me , they are sometimes easier to figure out what somebody else has done to a radio when the radio is in front me , and even then , I couldn't promise you anything.
  #6
Old 08-07-2007, 01:23 PM
Senior Member
Default
MC...i want to run this in my work van as a barefoot radio.thats why i need more than 2 watts.any good 29 should do 5-6 watt key.theres something done in here that isnt obvious to my eye .where should i start looking?if i cant figure this out i,ll either give it back or offer it for sale ..its a number 8 earnhart radio by the way......hhhmmm.....any takers ?
  #7
Old 08-13-2007, 03:57 AM
BANNED
KC2OST is on a distinguished road
Default
Is there a cap and resistor on jp36? (by the final)
If so, remove it and replace the jumper.
They usually put the resistor on the back of the board.
  #8
Old 08-13-2007, 10:25 AM
BANNED
freecell is an unknown quantity at this point
Default
"He just wants a tuned radio ,which a 29 should do roughly 5 to 6 watt DK with anywhere from 20 to 30 watt pep swing ,especially if this radio carriers a 1969 final."
if you're only getting 5 - 6 watts out of a 1969 in a 29 then you have a large degree of mismatch between both the output of the driver transistor (2314 or 1957) and the 1969 input and additional mismatch in the tank output of the 1969.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
