Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
HELP WITH TRIPPLITE 60 AMP SUPPLY
Reply
  #1
Old 02-05-2008, 11:56 AM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default HELP WITH TRIPPLITE 60 AMP SUPPLY
I need a transformer for this thing and I called Tripplie and they do not repair or sell parts if its warrantied they send a new one and if its not they said they will sell me a new one for $179.95 I dont need a new one nor will I ever buy another one after finding this all out. I just want to find a Transformer for this one that I have. Anyone have any Ideas on where the heck I can start with looking or anyone have a parts unit lying around?? Thanks for any help in advance this really has me P.OED.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #2
Old 02-07-2008, 09:54 AM
TonyV225's Avatar
Default
Ok I found through one of my parts distrubutors a 12 Volt 90 Amp would this work? I was thinkling this would be nice because there would be plenty of breathing room with a 90 Amp transformer in a 60 Amp supply if this indeed would work
__________________
  #3
Old 02-07-2008, 11:09 AM
rlnthndr is on a distinguished road
Default
Not sure about tripp lite but I was thinking that the transformers for alot of those supplies were 18-24VAC on the secondary then they are rectified and are regulated from there thru a voltage regulator and pass transistors.
Ask the tech support guys what voltage should you be seeing at the input to the rectifier. This should be the voltage you need for the secondary of your transformer.
__________________
Quote:
Originally Posted by JustinDePolis
Why do people want to argue when it's apparent that their ignorance surpasses their ability to learn?
  #4
Old 02-07-2008, 11:20 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default
My Tripp Lite PR-40a has about 25 volts DC across the filter cap before the regulator. I just measured it to be sure. That leaves plenty of room for the voltage to sag and still maintain regulation. You would need a transformer with about 18 volts AC on the secondary for that.I would go no higher as the regulator may not handle the higher voltage but the big problem is the extra heat the pass transistors must handle. At 60 amps,every extra volt means an extra 60 watts of heat.
On edit:
I just took a look at the schematic of the PR-60d. It has a dual winding secondary. One winding is for the power supply output and the other is for the regulator circuit. You will need a similar transformer unless you can install a second smaller transformer to run the regulator circuit AND know what you are doing.
  #5
Old 02-07-2008, 01:25 PM
Default
As QRN said 18VAC on secondary which would be @ 25VDC once rectified 18*1.414=25.5ish.
QRN is is possible I could get you to shoot me that shematic? Don't believe I have any for tripp lite PS's.
I will PM you an email addy if you will.
__________________
  #6
Old 02-07-2008, 03:27 PM
Justme's Avatar
Senior Member
Justme is an unknown quantity at this point
Default
For 60 Amp continuous you need an 95 amp transformer, x .707 = just 60 amps after rectification.
Voltage goes up then, amps go down remember?
  #7
Old 02-07-2008, 03:48 PM
Default
justme: Those ratings are for peak output. The continous ratings are somewhat lower at 48 amps.
rlnthndr: you can download the schematic for the PR-60d here.
http://www.cbtricks.com/miscellaneou...lite_pr-60.jpg
With thanks to Bennie.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
