SILVER STREAK 150 (2 X MRF455) ?  | |
03-31-2008, 02:04 PM
|  | Senior Member | | Join Date: Apr 2005
| | SILVER STREAK 150 (2 X MRF455) ? What is it about these little amps ? IM sure I've had 1/2 a dozen of these things over a few decades it would seem. (They work !  and whomever builds them ,IM guessing they have been building them for a long time)Seems like 1 watt DK usually does the trick on these little guys. IM getting to my question , (without using a cap resistor mod or not) Will use a 1 to 4 watt pep at 100% modualtion into this little guy . My numbers are ballpark 20 to say 60 audio watts on low (I could whistle 80 but that don't count) , 80 to say 120 audio watts on high (I could whistle 160 watts but that don't count either) . On just about anyone of these boxes I've had over the years they always seem to DK bigger numbers then I would expect on the high side of these little guys , IM guessing this is normal for these ? Keeping in mind, IM only talking about a 1 watt drive ? 80 seems like alot ? or is it just the way the box is built ? Thanks |
04-02-2008, 06:55 PM
| | 30 views and no clue ? hmmm |
04-02-2008, 08:16 PM
|  | Prestigious Member | | Join Date: Feb 2008 Location: too close to mexico
| | Quote:
Originally Posted by Switch Kit 30 views and no clue ? hmmm | The mrf455's are meerly 60 watt transistors so anything over 120 or so is fluff.
Data sheets don't lie, http://datasheets.foxdelta.com/mrf455.pdf |
04-02-2008, 09:54 PM
| | My question is why the high DKs on these with only 1 watt , the many I've had over the years all acted that way. Your data sheet means nothing to me unless you explain it ? why the high DK's on these little boxes at 1 watt compared to many others is the question. As far as fluff goes , I already said that didn't count. No offence to you Mack , but folks tend to ask simple questions (or look for simple answers) and I could drop a data sheet on somebody any day of the week weather i understood it or not ....kind of like this past thread ...... "Pill" questions... Thanks for the reply all the same Mack , the data sheet doesn't tell me why these little amps key higher then I personally would think they would on the high side of a 2 x 455 amp. I can believe the low side at 20 to 60 but 80 to 120 audio pep seems strange to me ? Is when a radio is perfectly tuned at 1 to 4 into this box , what happens to the 4 to 1 ratio from the box , this is why I "think" 80 watt DK would be high on this one ? NO ?
04-02-2008, 11:32 PM
| | BANNED | | Join Date: Apr 2005 Location: non-cartesian cyberspace
| | simply compare the 455 to another popular 60W transistor to answer your ?. http://www.firecommunications.com/trdbase/2sc2290.pdf
2SC2290....1 in 20 out, 13db., 12.5vdc @ 28mhz.
Ref: Po - Pi Graph, end page.
db = 10LOG(Pout/Pin)
db = 10LOG(20/1)
db = 10LOG(20)
db = 10(1.301)
db = 13.010 http://www.firecommunications.com/tr...mrf455rev0.pdf
Ref: Po - Pi Graph, mid page.
MRF455.....1 in 50 out, 17db., 12.5vdc @ 30mhz.
db = 10LOG(50/1)
db = 10LOG(50)
db = 10(1.698)
db = 16.989
the increased gain of the 455 allows it to produce (2.5X) more power output with the same amount of drive at the lower input levels.. the information is in the spec. sheets.
also, if we move both devices to 27mhz. the gain of both increase still further, the gain of the 455 increasing even still more than the 2290.
the Silver Streak 150 is an extremely drive sensitive Class C Amplifier.
04-03-2008, 05:38 AM
| | Senior Member | | Join Date: May 2005 Location: pa
| | hey freecell whats the specs on the 2879?just curious to see the gain on those. |
04-03-2008, 06:21 AM
|  | Senior Member | | Join Date: Dec 2006 Location: RICHMOND VIRGINIA USA
__________________ |
04-03-2008, 08:47 AM
That would explain the higher DK's on the high side on these with such a low input into them , thank you Freecell . |
04-03-2008, 05:18 PM
| | Quote:
Originally Posted by Switch Kit the increased gain of the 455 allows it to produce (2.5X) more power output with the same amount of drive at the lower input levels.. the information is in the spec. sheets.
That would explain the higher DK's on the high side on these with such a low input into them , thank you Freecell . | And it might have something to do with them big ole resistors feeding the rf into the input tranfomer which would probably vary from unit to unit.
Neat little box anyhow, I'll give you $40 for it and I won't tell anyone how bad you beat me.
04-03-2008, 10:00 PM
| | I was thinking more along the lines of 75.00 shipped Priority but haven't got there as of yet. Damned near mint condition as is. I sure appreciate the info on this one all the same. I was just surprised on why these little dudes produced such a healthy DK on the high side. My personal 4 x MRF454 box keys a little over 100 with a slightly over 400 watt swing , although I finally was able to see one of those XL 500s 4 x 1446s damned near swing 500 the other day (fluff or no fluff !) , blew me away ! This past year or so , between MOSFETS and the 1446 transistor , both have been impressive for what little knowledge I have on either , I really like those 1446s , they really seem to have some big balls on the 11 meter band ! As far as this little Silver Streak goes , the builder must have done well for himself , I remember these little guys from the mid -80s and there still selling them. I also remember a lot of the amps back then carrying Motorola Transistors more so, then the Toshiba's I see today ? I've heard cost had something to do with it nowadays. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 06:54 PM. |
