Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Cobra 200 GTL with no output power
Reply
  #1
Old 04-03-2008, 05:46 AM
Junior Member
Pilsener is on a distinguished road
Default Cobra 200 GTL with no output power
My Cobra 200 GTL got the well-known failure of the RD16HHF1 driver transistor.
This has been replaced, but I still get no output.
I have a good and strong signal all the way to one side of C 641 (left side of it as seen on the diagram).
On the "right side" of C 641, the signal gets weaker and weaker for each component.
No input signal is measured into the final stage transistors, and there is no output power and no reading on the meter.
The 2SC2290's has the required voltage of 13 VDC on their collectors.
No excessive current draw in RX mode. Only 0,35 A. And no heating of any components.
Any ideas ?
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
