Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Cobra 25 LTD Repair
Reply
  #1
Old 07-13-2008, 08:43 PM
Happy_Hamer's Avatar
Forum Administrator
Happy_Hamer has disabled reputation
Default Cobra 25 LTD Repair
I bought a nice looking Cobra 25 at a garage sale.
It powers up nicely, when I connect the mic I get a rapid and loud thud thud thud thud coming over the speaker. I thought it was the mic so I tried 4 other Cobra mics and same thing, as soon as a mic is connected the noise starts. Hooked it up to 2 other power sources and still the same thing.
Anyone ever encounter this?
Any thoughts where to start?
__________________
That's how I roll!!
  #2
Old 07-15-2008, 09:54 AM
Forum Administrator
Default
Anyone?
__________________
That's how I roll!!
  #3
Old 07-16-2008, 06:46 PM
Junior Member
pathfinder259 is on a distinguished road
Default
Could be a shorted audio chip.Have you did a p.a. test??Is the signal meter
detecting signal??I know you will not be able to hear the receive audio
without the mic connected.But you can put the radio on say channel 19
and see if the signal meter is detecting signal..Also as i say do a p.a. test..
Put the radio in p.a. mode.Plug an external speaker into the p.a. jack
Then connect your mic.Then plug your mic in,and see if you are getting
audio through the p.a. stage.This test will tell you if the audio chip
is functioning properly.If when you plug the mic in.In the p.a. mode,You
get the same loud thudding sound through speaker.Then you probably
have a shorted audio chip..Or it could be one of the large elect. caps
beside the audio chip..The audio chip will be the 10 legged i.c. bolted
to the right side of the chassis rail.Radio facing you,component side up.
The audio i.c. part number is TA-7222AP
  #4
Old 07-17-2008, 12:28 PM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
what 259 said, tell us more. I'd like to hear that rapid thud thud thud , Good luck Hamer
  #5
Old 08-17-2008, 02:49 PM
Junior Member
RUDEDOG369 is on a distinguished road
Default NOISE
I HAD THE SAME THING HAPPEN WITH A DAK9 IF THE RADIO IS QUIET WHEN YOU UNPLUG THE MIC IT PROBALY NEEDS TO BE WIRED FOR MIC,OR MIC NEEDS WIRED.
Reply
Bookmarks
Tags
cb radio, cobra, cobra 25
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
