Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Driving a 6 pill fatboy amp
Reply
  #1
Old 11-04-2008, 03:05 PM
Junior Member
nickybots110 is on a distinguished road
Default Driving a 6 pill fatboy amp
I just picked up a 6 pill Fatboy amp fo a unbelivable price. I know I need to drive it with something but I'm not sure of whats the best driver for it. Any info would be great. Thanks
  #2
Old 11-04-2008, 05:00 PM
Senior Member
formulamojo is an unknown quantity at this point
Default
A nice 2 pill.
Set your radio DK so that the 2 pill dk's around 75-80 watts and it will drive the 6 pill nice.
__________________
MoJo
www.mojoenterprises.us
  #3
Old 11-04-2008, 05:23 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
300 watts to drive six 2879's ?
75 to 80 watts deadkey into 6 transistors that only need 7 to 10 watts each for max clean output ?
  #4
Old 11-04-2008, 05:42 PM
Junior Member
Default
I have a TS 350 and a TS 250. Is one better then the other to use. I know the 250 has 2290's and th 350 has 2879's. Or should I get a 2 pill fat boy
  #5
Old 11-04-2008, 08:07 PM
Senior Member
Tony is on a distinguished road
Default
what radio are you driving this with?
  #6
Old 11-05-2008, 07:51 AM
Junior Member
Default
Cobra 29
  #7
Old 11-05-2008, 10:00 AM
Senior Member
Crusher is on a distinguished road
Default
The 250 or 350 will work fine. Does either one have a variable? I use 2 1446's to drive a 6 pill amp. I would set it so that radio turned down and use variable on 2 pill amp so that you dead key about 250-300 watts and let it swing. This will be easier on electrical system and give you nice sounding audio. You can experiment from there. but that should get you in the ballpark. If you DK 60-70 watts into amp on a stock system your audio will start to get clipped (distorted)
  #8
Old 11-05-2008, 10:03 AM
Senior Member
Default
Yes booty.
Ask Mackmobile43, he built my 6 pill that is what he recommended.
I use a ts 350 DX as a driver. Might DK a little less it is a rat shack meter after all. Probably more like 40-50 bird.
Never had a complaints about distortion.
__________________
MoJo
Reply
Bookmarks
Tags
cb radio, fatboy amp
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
