Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
what happend
Reply
  #11
Old 12-05-2008, 07:45 PM
190 190 is offline
Senior Member
190 is on a distinguished road
Default
mine was a straight 4 pill with the variable on the amp there wro220. the variable on the amp went shit house. did all kinds of weird things.i bypassed the variable and the swr went really high. had the variable fixed and now i use it as a foot stool and run my eastcoast straight 4 pill non-variable amp. no more trouble.
Worldwide Radio Forum
  #12
Old 12-06-2008, 04:05 AM
psycho's Avatar
Senior Member
psycho is an unknown quantity at this point
Default
Quote:
Originally Posted by WR0220 View Post
Hey 190, isn't this the same problem you had with your (fatboy) amp?
Replace or bypass the (defective) variable control on the amp...
If the amp swings to the same power before and after the "problem".....level then it can't be the variable. The only way to run those amps as a final amp is with the variable wide open and radio adjusted for the proper dead key.
__________________
It's a lot cheaper to supercharge a wattmeter than to buy a bigger amplifier!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
