Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
need help with President Washington w/upD858
Reply
  #1
Old 04-08-2009, 03:52 AM
Senior Member
skybolt58 is on a distinguished road
Default need help with President Washington w/upD858
I got this president washington with the 858 chip, Now the rec. is low and I installed one of those 621 pre amps. it helped a little, but not like it was when new. Now I was told the am regulator needs to be replaced because they are a known bug? Where is it? also it is starting to have a modulation glitch, when I key up for the first second or so. they say I sound fuzzy? but after a bit it clears right up? now could that be the audio IC? where is it? there is no cb shops anywhere near me. I am handy with soldering so that isn't a problem? but tuning is?
ALSO? is there a way to hard wire in a freq counter in the 858?
  #2
Old 04-08-2009, 05:16 AM
Bionic Chicken's Avatar
Senior Member
Bionic Chicken is an unknown quantity at this point
Default
Rather than throwing parts at the radio it sounds like it needs a good alignment on transmit and receive. Once that is completed you will be able to tell if there is a component problem. Changing parts out with a bad alignment can actually cause you more problems than you have.
BC
__________________
BC
  #3
Old 04-08-2009, 07:01 AM
Senior Member
Default tired ol washington
I did bring it to a place just up past watertown ny. he said it is old that he did the best he could. the tuning problem is once I do replace parts. it is tuned the best it can be. it is LOUD but fuzzy in the first second or 2 then cleans right up. and this is on many mics. I don't know, I just may trash it! it is over 35 years old
  #4
Old 04-08-2009, 05:10 PM
mechanic's Avatar
Senior Member
mechanic is on a distinguished road
Default
The older 858 chassis is a great one but had a few bugs. From your description sounds to me like it might be the T/R relay... Not easy to find a new one... But! It can be cleaned...
The plastic cover is held in place buy two cleats, one on each side... You can make a tool to remove this cove by taking a cheap screwdrive and bending the tip into a J shape then as you pull the side carefully away, lift and do the other side whilst holding up. A bit tricky but just be careful!
Do not use anything harsh on it like a spray or a file. You need to burnish the contacts, there is a tool made for this but I found that using a match book striker works pretty good, just tear it off so it is small enough to work with and gingerly, carefully clean the contacts. You just want to make them clean not ware them down to the base metal.....
FWIW... If the AM regulator was bad there would be no AM carrier....
Good luck! Mechanic
  #5
Old 04-08-2009, 09:47 PM
Senior Member
Default web info I found
Thanks for the scary info, I was told to stay awat from that relay because they were like gold! but about the regulator, below I found on many web sites?
KNOWN BUGS
The AM regulator 2SC1419 is WEAK. UNSOLDER it and toss it in the trash.
Replace it with a GE-66, ECG-152 or a NTE-152.
Relay buzzes on SSB, no am transmit, lights go dim, or the fuse pops sometimes?
Replace C179 ( a 2.2uF 25v tantalum cap located near finals) with a standard 2.2uF electrolytic capacitor.
PAY ATTENTION to the "+" and "-"!!!
  #6
Old 04-09-2009, 09:05 AM
mechanic's Avatar
Senior Member
Default
Cleaning the relay isn't too hard, just be careful! Just one or two strokes of the burnishing tool should be all it needs!
mechanic
  #7
Old 04-09-2009, 09:13 AM
mechanic's Avatar
Senior Member
Default
BTW it will not hurt to replace the regulator either, it is located screwed to the heatsink toward the back of the radio. Replace the tantalum capacitor, it is blue and located between the finals about an inch into the board. You can use an ordinary polarized one of the same value.
mechanic
  #8
Old 04-09-2009, 11:46 PM
Senior Member
Default OK?
Hmm,, which one is the am regulator and here is a pic..
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
