Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Need D104 mic wiring 4 pin to Cobra GTL 2000 5 pin
Reply
  #1
Old 05-04-2009, 03:53 PM
Junior Member
chuck97405 is on a distinguished road
Default Need D104 mic wiring 4 pin to Cobra GTL 2000 5 pin
I have a D104 mic old 4 pin and I need to wire this up to a Cobra GTL 2000 5 pin plug . Can the shield and the the common wire be tied together since I only have a 4 wire cable on this D104 or do I need to run a new cable I am kind of unsure at this point. On my D104 Mic the colors are red, shield, pink, and a yellowish/green wire. Can anyone help me?
Worldwide Radio Forum
  #2
Old 05-04-2009, 04:04 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
All you need is a 5 pin plug.
Astatic (6 wire)
1- White
2- Shield
3- Black
4- Blue
5- Red
Yellow N/C
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 05-04-2009, 08:37 PM
Junior Member
Default D104 mic wiring
Since I only have a 4 wire cable on this D104 mic there is no blue wire. Do I need to run a brand new cable between the mic plug and the inside of the D104 mic? Can't I make this work without having to connect 5 wires.?
  #4
Old 05-04-2009, 08:47 PM
Rob KI6USW's Avatar
Senior Member
Default
Astatic (4 wire)
1- White
2- N/C
3- Black
4- Shield
5- Red
If you have a 4 wire mic; that will do it...
__________________
What gear do I use?
  #5
Old 05-04-2009, 09:01 PM
Junior Member
Default D104 Mic wiring
I will try this wiring you have suggested. Where did you get this information. I have been checking on the internet in many different locations. I even looked at the manuf web site and it did not give the wiring for a 4 wire cable.
  #6
Old 05-05-2009, 05:05 AM
Sonwatcher's Avatar
Senior Member
Sonwatcher is on a distinguished road
Default
Model: 90, 140gtl, 142gtl,148gtl,2000gtl, 2010 Standard wiring:
1-Audio
2-Shield
3-Receive
4-Switching Wire
5-Transmit
Wiring the Cobra Microphones
Try this without pin 4
__________________
http://www.haminfobar.co.uk
  #7
Old 05-05-2009, 08:17 AM
Senior Member
hotrod is on a distinguished road
Default
Quote:
cbtricks.com says exactly the same as rob.have ya tried it yet
__________________
magnum delta force
magnum omega force
uniden grant
cobra 2000gtl
sirio z180
skythumper65dx
  #8
Old 05-05-2009, 12:38 PM
Sonwatcher's Avatar
Senior Member
Default
You're correct. On the 4 pin plug they switch the shield to pin 4 whereas the 5 pin plug has the shield on the 2 pin .
__________________
  #9
Old 05-29-2009, 04:52 PM
psycho's Avatar
Senior Member
psycho is an unknown quantity at this point
Default
Quote:
1-Audio
2-Shield
3-Receive
4-Switching Wire
5-Transmit
I believe you need to jump pin 4 to pin 2.
__________________
It's a lot cheaper to supercharge a wattmeter than to buy a bigger amplifier!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
