Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
I just got a Vintage Turner SR90D, any info?
Reply
  #1
Old 05-25-2009, 08:35 AM
Senior Member
Cityboy is on a distinguished road
Default I just got a Vintage Turner SR90D, any info?
I just got a really nice vintage Turner microphone that is all stainless steel on the outside and has model # SR90D. I think I have seen others refer to it as the 90 D or just like a Collins microphone. Any help would be apprecitated; I plan to make it usable in a 4 pin configuration for my General Lee if possible. Maybe some of you have run across this one, I believe it was manufactured around 1959-1960's. If you have any specs or owners manual you can pdf I would greatly appreciate it. Thanks
Worldwide Radio Forum
  #2
Old 05-30-2009, 02:35 PM
Senior Member
Default
Just got the mic in and it is very good condition and is very much vintage. It has a tension PTT switch with 4 long metal bands that disconnect and reconnect as you pust the PTT switch. The element is an Astatic 3-62 ceramic element that is heat and moisture resistant it says. It is a 4 wire hookup. 1 red, 1 black, 1 shield and 1 white. Any help would be helpful. I did find it in a 1972 turner microphone catalog.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
