Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
AB1 Amplifier & Class C Amplifier Sideband comparison
Reply
  #21
Old 06-21-2009, 03:22 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
Quote:
Originally Posted by flush View Post
Wow that was intresting. I guess you need to choose your words when using a C box with a cap on the relay...
Thanks for taking the time to do the test mack.
Glad to do it and I have to admit my radio was off freq just a tad but I can blame it on my sons ear as he tuned the reciever and controlled the recording on and off.
The 430 kenwood only has a stock filter and is narrow as hell.
Worldwide Radio Forum
  #22
Old 06-29-2009, 08:40 PM
Junior Member
Stevenp55 is on a distinguished road
Default Both radios?
Hey Mack, same radio different amplifiers. The test may have been a cheat. Notice that the "AB1" amp was narrated as sideband. Were all the tests on sideband? Clearly "C" is not for side band by nature. We need a new test, same equipment. Comparison fixed on AM, comparison fixed on SSB. Then we will know. The difference in the test produced very clear audio on SSb with an AB1 amp, and lesser quality on the other amp, but conditions unknown. If we take the test as SSB all equal, then the AB1 had superior modulation, hello, modulation!
  #23
Old 06-30-2009, 01:34 PM
psycho's Avatar
Senior Member
psycho is an unknown quantity at this point
Default
Quote:
You know Booty is on a crusade to educate everyone about the evils of class c amps.
The test done would be like comparing a top fuel dragster to a Sprint Cup car in the quarter mile........the top fuel car is way better but the sprint cup car is way better in the turns.
Booty is just ranting about his disdain for class c once again, he is bored.
__________________
It's a lot cheaper to supercharge a wattmeter than to buy a bigger amplifier!
  #24
Old 06-30-2009, 05:47 PM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
hello psycho , i see youre still cheerleading the class C banner . i have to admit , you were very instrumental in my choosing of equipment when i first came around here . once i saw how much folks here respect your opinions , i knew then that if you didnt like something it was probally the better way to do things .
thanks for providing such a fine example of what not to do .
__________________
  #25
Old 06-30-2009, 05:56 PM
Senior Member
n8fgb is an unknown quantity at this point
Default
Class "C" amps are not suited for AM, let alone SSB. They are not linear enough to properly amplify the signal. They are intended for FM and CW.
Rich
  #26
Old 07-01-2009, 07:03 AM
Senior Member
The Jerk is on a distinguished road
Default
Although not considered the best option for SSB, that comparison shows a class C will indeed work on SSB. I was actually under the impression that a class C on SSB would be a whole lot worse, in fact I was under the impression it wouldn't work at all. If I only had, or could afford, a class C amplifier; I would not be concerned about using it occasionally on SSB.
And to be quite honest, only someone with a base that could fine tune that signal in, for an hour long conversation, would ever really know (or really care)...most of our DX contacts are for under a minute, then we move onto the next one. I wouldn't be able to tell if that was a class C or not...I would have assumed it to be a poorly tuned radio or the conditions at that time, which brings me to my next point.
Garbage in is garbage out...I would like to know how that Longstreet was modified, if at all. A clipped radio, overmodulating, would likely cause more issues and heartburn at the receiving end than that Class C amp.
For the record, I run two SSB setups; the radios are tuned by a competent technician into AB-1 amplifiers. So I really don't have a dog in this fight.
  #27
Old 07-01-2009, 01:01 PM
psycho's Avatar
Senior Member
Default
Quote:
Rich
Class C amps aren't suitable for AM??????? Here we go again.
Someone better break the news to Joe at Davemade.
__________________
  #28
Old 07-01-2009, 07:12 PM
Senior Member
Default
Rich
Classes of Amplifier Operation
__________________
  #29
Old 07-01-2009, 08:31 PM
Supporting Member
W5LZ is an unknown quantity at this point
Default
A class C amplifier can work on AM or SSB if it's operated in the linear portion of it's amplification curve. That doesn't mean it will work -well-, just that it will work. Why is a class C amplifier touted as the 'end all' for AM amplifiers? Cuz you can see more power output than for other classes of amplifiers. You don't have to know just a tad bit more to figure the biasing needed for proper operation. And because they've been around dang near forever so have become a sort of 'standard' for CB amplifiers. If it's 'older' it's gotta be better, right? Yeah, right. You've got your choice, big watts or good quality signal. You decide, then live with it.
  #30
Old 07-01-2009, 08:48 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Quote:
Thaaaaat's It!!!
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
