Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Recommend a Filter
Reply
  #11
Old 07-07-2009, 07:22 PM
Senior Member
The Jerk is on a distinguished road
Default
Quote:
Originally Posted by moleculo View Post
Bencher YA-1....they're a little pricey, though.
I was looking at these...they looked like they were around $90?
Worldwide Radio Forum
  #12
Old 07-07-2009, 07:44 PM
AkBowtie is on a distinguished road
Default
Around $90 seems right, I've seen them 65-125 new. I got mine used for $40
Spend the money, find either a new or used YA-1, their money well spent versus the 10 and 20 dollar stuff you could waste money on and not be happy.
First thing though would be to see if you even interfere with the neighbors.
__________________
  #13
Old 07-07-2009, 09:45 PM
loosecannon's Avatar
Senior Member
loosecannon is on a distinguished road
Default
check ebay for the low pass filter.
drake and bencher both make very good ones.
just buy one that is advertised in the ham market and stay far away from any that are advertised in the CB market and you will be fine.
i would not buy a new one as they are very expensive, and there are always good deals to be had used because so many people buy one thinking that it will solve their problems only to find out that harmonics were not the cause of the interference to the neighbors.
OK, this is from experience:
DONT TELL YOUR NEIGHBORS THAT YOU MIGHT BE INTERFERING WITH THEIR STUFF!!!!!
the reason for this, is that most people have absolutely no clue about RF, radios, CB, interference, or electronics in general.
if you tell them that you might interfere with their TV or phone; every time their cable goes out or the phone makes a funny noise, they will be at your door blaming you.
and even when you KNOW 100% for sure that you weren't even on the radio, they will still think it was you, and will continue to think it forever.
now, if you happen to be friends with your neighbors, then there is a slight chance that they might not blame you.
yes, this is just my opinion, so hopefully others will chime in and say whether their experience has been similar to mine or not.
a question i have for you is, is the law on your side?
by that i mean, do you live in an HOA or other antenna restricting neighborhood?
if so, then you are screwed and are at the mercy of your neighbors.
if not, then you just need to make sure that DTB tunes your radio within legal specs.
make sure he sets your deadkey at about 3.5 watts, and that he sets the modulation so it wont exceed 100%
also, have him tune the 54mhz coil in the radio with his spec analyzer to make sure you arent putting out any harmonics.
if you do this, you really dont need a low pass filter, and if you do interfere with anyone's electronics; you can be sure its because of the cheap way they were manufactured and has nothing to do with your station.
you are in the enviable position of being part of the 1% of cb'ers that operate a completely legal station. LOL
if you interfere with their cable TV, tell them to call the cable company.
if you interfere with their phone, tell them to call the phone company.
if the power lines near your house interfere with your radio, call the power company and tell them to fix the problem.
if you are worried about your antenna being seen, let me know and i will tell you how to make an invisible antenna.
as long as you dont tell anyone that you have a CB setup, no one will bother you.
good luck,
__________________
"Man shall never reach the moon, for such a quantity of gunpowder would be needed as to gravely injure the crew."
~ Children's Encyclopedia, 1926
  #14
Old 07-08-2009, 01:47 PM
Senior Member
Mr Clean is an unknown quantity at this point
Default
I run 500 watts avg at the house with no filter. Clean radio helps alot. Ice Bencher Drake all are good.
  #15
Old 07-08-2009, 07:12 PM
Drifter's Avatar
Senior Member
Location: Under a coconut tree in the Carribbean sipping on white rum and coke!!!
Drifter is on a distinguished road
Default
I totally agree. Don't go around telling your neighbors that crap. You are asking for trouble. Just keep a low profile and do your thing. Make adjustments if you get complaints. As far as low pass filters go. Bencher or ICE will work. Also try to ground your equipment.
__________________
Yaesu 101E
Signal Engineering lightning 6 quad Antenna on a 60FT crank up tower.
  #16
Old 07-11-2009, 08:25 PM
Junior Member
tsquared is on a distinguished road
Default
Thats not a cb antenna, it's my new bad bear hd tv antenna !
  #17
Old 07-11-2009, 08:39 PM
Senior Member
Default
Thanks for the responses...
I set up the dipole and a with a handheld, SWRs are typically less than 1.5:1. I have goofed around, and no one has said anything...I haven't bled over anything inside my house, nor have I bled over any of the nearest neighbors (or they would have told me).
I think I may be good to go for now, until I get a base radio. But it will be barefooted as well.
  #18
Old 07-11-2009, 08:48 PM
Junior Member
Default
My dipole does not bleed. My antron 99 lives up to it's nickname.
I use a tx star 350 with a cobra 2000.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
