Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Swing Kits
Reply
  #1
Old 07-07-2009, 02:27 PM
undertaker's Avatar
Undertaker
undertaker is on a distinguished road
Default Swing Kits
What are swing kits and what do they do??
__________________
"I drink well with others"
Master Mason
32 Degree Scottish Rite
Worldwide Radio Forum
  #2
Old 07-07-2009, 02:37 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
A swing kit -used when the dead key of a radio has been lowered- will give brighter modulation into a linear amp.
This provides two functions. The lower dead key of the radio will create favorable modulation scale so as not to overdrive the input of the amp - while the swing mod (usually a capacitor and a resistor) allows the radio to reach its peak modulation while in a lower power mode. Not to be done unless a linear amp is to be used.
It doesn't harm the radio - as much as it more accurately matches the radio to the input of the amp. I wouldn't do it to a radio - unless I intended to use an amp. Using a swing kit on radio w/o a linear cn be done; but it will give up some average power in order to make louder, clearer modulation...
Two cents...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 07-07-2009, 02:48 PM
undertaker's Avatar
Undertaker
Default
Thanks Rob i was just wondering about them...
__________________
Master Mason
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
