Texas Star 350DX Review
QS - I have a TS 350 as well. I don't use it - as I don't have a big enough of a supply to run it. I have a 30 amp Vista supply; but the TS 350 will draw more current than most two-pill amps. You may want to read the review from CB Radio Magazine that I have linked above.
If I am going to use a linear, I will probably use it in my mobile. My OmegaForce does fine as a base radio with ~65 watts PEP and a decent antenna. But if I had to run the TS 350 on my base - I would get the Pyramid 42 amp supply. That way, I wouldn't be straining a lesser supply...
__________________ What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770. "...The 444 in San Jose CA; the Central Gold Coast..."
