Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Texas Star DX250(V)
Like Tree3Likes
Reply
  #1
Old 09-03-2009, 11:20 AM
Quiksilver's Avatar
Senior Member
Quiksilver is on a distinguished road
Default Texas Star DX250(V)
Are the variable pots on the Texas Star amps really that bad? Would it just be better to just go with the non-variable models? I would like to run a Texas Star 250 on my Astron RS35M (if possible), and the variable model would allow me to keep the wattage/amps down to acceptable levels. What watt/amp output/draw numbers would you see on the non-variable model?
If I go this route, I wont need to buy another power supply in addition to the amp.
Thanks for the input!
  #2
Old 09-03-2009, 11:58 AM
Moleculo has disabled reputation
Default
IMO, it's easier to just reduce your drive level to achieve the desired output from an amp like that.
  #3
Old 09-03-2009, 12:23 PM
Quiksilver's Avatar
Senior Member
Default
Drive level would be kept to a minimum with a Cobra 2000GTL as the driver.
  #4
Old 09-03-2009, 03:51 PM
Senior Member
9C1Driver is on a distinguished road
Default
The pots are fine if you keep the AM dead key at 1.5-2 watts and max peak input to 20 watts. People always ASSume since it's a Hiiiiii Driiiiiive they can dead key 4-10 watts into it. Then they wonder why they burned up the pot or keying transistor.
Your Cobra 2000 will work great. The Texas Star 250 will run fine wide open on a 35m power supply too. Sounds like your good to go.
  #5
Old 09-21-2009, 01:22 PM
bigred222's Avatar
Key Up City Radio
bigred222 is on a distinguished road
Default
i hear that the variables in these sometimes fail also. But i would just keep your drive levels low and let it swing from there. No sense in burning up the input section because you feel like throwing a fat deadkey.
73's
Red on the pile wavin
__________________
Galaxy 95T/146GTL/Wilson1k/A99 40ft to base ele 375ft
  #6
Old 09-21-2009, 02:10 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
As far as output PEP between the variable and straight pushbutton models you will see the same power out of either or remember its the same
2 / 2sc2290 layout or board its justv that one has the knob and one just uses the pushbuttons the transistors is rated at 80 watts a peice and that dont change its what they are period.
I have 4 Texas Star amplifiers 2 500 1 400 and 1 1600 the 400 and 500's are pushbutton the 1600 has 2 rocker switches (ON/OFF AM/SSB0 the power on the 1600 is also controled by drive or input power.
You have to remember that running these on the lightside keeps them clean across the band and like with anything if you treat it mildly or dont push it or beat the piss out of it well... the lifespan is greater and more trouble free.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #7
Old 09-21-2009, 05:20 PM
Quiksilver's Avatar
Senior Member
Default
Thanks all!
I went with the DX250 (non-V) Got my Cobra 2000GTL D/K set at 2W swinging to 18W AM, 22W SSB.
  #8
Old 06-21-2014, 12:56 PM
Oatmeal's Avatar
Senior Member
Oatmeal is on a distinguished road
Default
I no this is a old, old post but like to ask anyways a question about this amp.
I've got a Cobra 2000 as well, mine does have the variable power installed in it, and you can drop the dk down to zero watts, and goes up to 6 watts...and will swing 20 watts give or take a couple watts...
Ok, which one of the TS 250 amps would work best with this radio?...
Or, if it was going to be used for a driver someday just go with the variable in one ?.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
