Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Bad Power Supply, Need Ideas
Reply
  #1
Old 09-29-2009, 02:10 PM
Wire Weasel's Avatar
Senior Moment
Wire Weasel is on a distinguished road
Default Bad Power Supply, Need Ideas
Picked up a 30amp supply. Knew had at least 1 problem. Output was double voltage, showed 24volts. Figured 1 of the voltage regulators was bad and would be an easy fix.
Sure enough, 1 of the 7 regs. was bad. Replaced. Delighted to find normal output voltage in the 12v range but when tested under load the voltage dropped down to around 2 volts.
Any idea what to check next?
__________________
Welcome to the WWRF. Plenty of Free Parking and with 5,000 posts you get egg roll
  #2
Old 09-29-2009, 02:49 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Are you sure that when whatever happened to it didnt spike any of the other regulators if its an older supply ide just repalce them all or work my way back from the one you replaced.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #3
Old 09-29-2009, 02:57 PM
Senior Moment
Default
No I'm not sure Tony but thanks for the idea.
__________________
  #4
Old 09-30-2009, 05:57 AM
unit_399's Avatar
EL CAPO
unit_399 is on a distinguished road
Default
Weasel -
If the unit has an overvoltage protection circuit, maybe it was misadjusted by the previous user when the output went to 24vdc. Just a guess?
- 399
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Just wanting to share with you all my new power supply Cotton Mouth Installation & Station Setup 10 08-22-2009 08:04 PM
Interesting reading, datsun66 General Ham Radio Discussion 3 08-16-2007 08:16 PM
CHEAP Power Supply Hook948 General CB Services Discussion 14 04-25-2007 07:25 PM
Iota Power supply Lazybones1222 Announcements & Open Forum 6 06-13-2006 07:34 AM
Powered by vBulletin®
