Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
not transmitting
Reply
  #1
Old 10-11-2009, 03:16 AM
Junior Member
belley is on a distinguished road
Default not transmitting
hi guys i jus t got an ax144 uniden ssb rig the problem is it wont transmit
everything else works fine but when i push the mike i get nothing no signal strength the meter dont move i tried another mike the same thing the meter works fine receiving upon inspection everything looks fine but im no tech any help would be great thanks
Worldwide Radio Forum
  #2
Old 10-11-2009, 03:39 AM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Do you have a SWR meter? Or a watt meter?
Need more details please...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 10-11-2009, 04:09 AM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
No output but receive is fine usually = bad final transistor. You can check this by using another radio close by or on the bench like a handheld transmit with the non functioning radio and see if you get a slight signal on test vradio or receive radio.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #4
Old 10-13-2009, 03:39 AM
Junior Member
Default
thanks guys i tried transmitting from my radio to another and it was faintly heard i got to scream down the mike to be heard by other stations the same with another mike and yes the mike gain is on full and yes i have a swr meter thanks wayne
  #5
Old 10-22-2009, 06:55 PM
psycho's Avatar
Senior Member
psycho is an unknown quantity at this point
Default
Quote:
Sounds like you are only transmitting on the driver transistor, possible blown final.
__________________
It's a lot cheaper to supercharge a wattmeter than to buy a bigger amplifier!
  #6
Old 10-22-2009, 06:58 PM
TonyV225's Avatar
Senior Member
Default
Exactly
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
TRANSMITTING doctor Digital Modes Discussions 5 09-23-2009 07:06 AM
CB Operators and others Get FCC Warnings C W Morse FCC & ARRL Activity 32 09-04-2009 06:17 PM
transmitting station gregry08gt500 General Ham Radio Discussion 1 12-03-2008 01:36 PM
CBer warned about transmitting "non voice". C W Morse FCC & ARRL Activity 8 03-18-2006 08:19 PM
galaxy 2100 transmitting off freq missouri 69 Tech, & Repair 1 12-31-1969 06:00 PM
Powered by vBulletin®
