Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Colt Radios
Reply
  #1
Old 10-24-2009, 09:23 AM
Junior Member
Dave W is on a distinguished road
Default Colt Radios
I'm an old hand at Cb and have been tx'ng since the late 70's, mainly a mobile set thrown in the Car or works truck, However, I'm just setting up a small shack and have started with Colt 355 FM, General Electric AM & a Euro AM band set.
My question is: Does anyone know who originally built the Colt? Wasn't Midland was it?
I'm trying to find a manual for it to assertain the correct frequency band.
If anyone can help it would be much appreciated!
Worldwide Radio Forum
  #2
Old 10-24-2009, 09:45 AM
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
I had a Cardon radio that was built by a division of Midland called Midland International. It was an Iroquois 40. It was 100% identical to the Colt 1000. IIRC Midland radios were made in Missouri USA while the Midland International radios were made in Japan. Same company,two divisions.One domestic and the other international.In short,yes,the parent company of Colt was Midland.
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
  #3
Old 10-24-2009, 10:11 AM
Junior Member
Default
Thanks for that!
I'll have to try & track down a manual through midland then. Gives me another avenue to try!
  #4
Old 10-24-2009, 04:45 PM
MisterFatty's Avatar
Senior Member
MisterFatty is on a distinguished road
Default
Cybernet made many/most of the Midland Circuit boards (late 23 channel production-40channel), It has been a few years but from what I remember Cybernet also made most/all? of the boards in the Colt radios, not positive on the AM/FM only radios though. I would be looking at some of the other Cybernet boarded radios from the same era if your having trouble finding.
I guess your definition of built may be the question, at the component level it was pretty much Cybernet...
  #5
Old 10-24-2009, 05:58 PM
jazzsinger's Avatar
Senior Member
jazzsinger is on a distinguished road
Default
I think you'll find some colts (210) and many midlands (2001,3001,100m etc) were made in korea by if i remember correctly maxon,the rest were mostly cybernet japan chassied radios.
If i'm not mistaken the colt 355fm was one of the korean made colts.I havent seen that model but it wouldn't surprise me if it was a colt 210/295/vice president roy/cobra 19x/21xfm clone with a fm mod/demod board fitted.may be an exact clone of cobra 21xfm.
  #6
Old 10-24-2009, 06:27 PM
Senior Member
Default
Ya I probably should have clarified I think they changed over from Cybernet sometime around when they started with the Pro series radios... What was it, late 80s, or early 90s? think that was about the end of the Cybernet popularity. Have to admit, I stayed away from the Cybernet chassis radios as much as possible, mostly personal preference, but I always much preferred some of the other chassis available at the time, Mostly Uniden stuffed boards I guess...
  #7
Old 10-24-2009, 06:32 PM
jazzsinger's Avatar
Senior Member
Default
Quote:
very understandable as cybernet and maxon chassis ain't known for being quality compared to unidens and ranger chassis.i still avoid them like the plague.
  #8
Old 10-27-2009, 08:46 AM
Administrator
Default
Interesting that you mention the board qualities. I had a Midland 13-898-B 23 ch SSB base that was a Midland International made in Japan. A friend of mine also had a 13-898-B but it had simply Midland on the front panel and was made in Missouri USA. The board quality was like night and day. The board in my radio seemed thicker and heavier and had all the component leads clipped before soldering making for a nice neat and smooth solder connection whereas the board in his radio had long component leads still sticking out of the solder pads. They were cut off at differant lengths and just plain looked like crap compared to mine.The wire harness in mine was also dressed neater and tighter as well.Not sure if they were differant boards or just a differance in quality control.
__________________
  #9
Old 10-27-2009, 09:06 AM
seedkey is on a distinguished road
Default
I agree with you QRN,
I've had lots of cybernet boards and thought the quality was very good. on the other hand Maxon built boards were awful
  #10
Old 10-27-2009, 11:27 AM
Junior Member
Old Goat is on a distinguished road
Default Colt Info
Check out CB tricks good luck RAY old goat (525)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
what radios have the best ears ? BOOTY MONSTER CB Band and CB Radios 28 03-27-2009 10:02 PM
New Radios vs. Old School Uniden Slam Dunk CB Band and CB Radios 2 11-26-2007 07:17 AM
Colt Excalibur & Kraco These Base Radios Any Good? DJboutit CB Band and CB Radios 15 09-15-2007 11:16 PM
President Lincoln .. Uniden HR-2510 .. same radio's, or not? Bolke The Bear CB Band and CB Radios 12 08-01-2006 07:06 PM
Powered by vBulletin®
