Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
lil wil w/ linear
Reply
  #1
Old 10-30-2009, 01:57 PM
Junior Member
speterson1011 is on a distinguished road
Default lil wil w/ linear
Ok so I have a lil wil antenna going at 1 to 2 and getting 5miles barefoot with my cobra ultra 19 radio. I have the cobra 19 radio tuned up at 8watts instead of the 4 watts it was stock. How well will it work with a 110watt linear or another kind of amp? I'm thinking around 20 to 25 miles? The antenna can handle 300watts. All criticism is welcome thanks
Worldwide Radio Forum
  #2
Old 10-30-2009, 02:01 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
Do not use an amp on that antenna, you will regret it.
__________________
I U 212
  #3
Old 10-30-2009, 02:47 PM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
ive used a 2x1446 (200 watts PEP) on mine for almost a year and never had a issue . i still have the same lil will for a backup . i would not recomend a 2x2879 on one . the 200 watts into a 10k is much more effective .
__________________
  #4
Old 10-30-2009, 03:33 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Hmmm...
Linears work better with the power in the radio turned down to 2 watts; not 8 watts! That is, the dead key watts (keyed up mic w/o talking).
I think - as BootyMon pointed out- that 200 watts is all you would want to put into the Lil Wil.
Personally, I would get a REAL Wilson 1000 antenna instead of spending money on the linear. The antenna is ALWAYS the MOST IMPORTANT part of ANY RADIO! Besides, the Wilson 1000 can hold a lot more wattage than a Lil Wil can. But the real advantage of the Wil 1000 is the sensitive receive and outstanding transmit characteristics! So it is a question of where the money is best spent - I think. Anything that improves your transmit AND receive is a plus; but it is still best done by using a superior antenna.
Besides, linears are illegal for non-Hams. Of course, this doesn't mean that non-Hams don't use linears! They do. But if you use one without discretion, you might get cited by the FCC. Using a linear in a mobile is usually more common and bit more acceptable; that doesn't mean it is legal. It just means that it both harder to track down and it rarely affects local folk who might complain.
There you have it!
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #5
Old 10-30-2009, 04:11 PM
Senior Member
Lazarid Anarion is on a distinguished road
Default
I had a 2950 Ranger on a Lil Will ......Even when I took the time to tune the swr down to 1:1 on a low power setting,5 watts on AM when I went to ssb and turned the power up to full power,25 watts on same frequency I could see the swr meter I was using start to rise to around 1.5:1 +/-
I am pretty sure you will experience the same results if you apply a good deal of power to that antenna.
The Lil Will is a fine antenna,dont get me wrong.I worked all of North America with a 2950 Ranger ( factory power setting of 25 watts ssb) and that antenna out of a pickup.But I would have to say stay below 50 watts to that antenna to be safe even though the antenna is rated for 300 watts
If you are going to run any power to speak of,50 watts + go to a Firestick 2 ,Pred 10K, Wilson 3k,5k, or some other type that will take well over what you plan to run to be safe,your radio and kicker will thank you
  #6
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
Quote:
Why do I have visions of those little glow sticks you can buy?
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
  #7
Old 10-30-2009, 06:15 PM
Supporting Member
W5LZ is an unknown quantity at this point
Default
To answer the original question.
Would doubling your output power about 4 times increase your 'range' by about 4 times? I'd have to say it -might- be a possibility, but it also might not be. You can't estimate 'range' by power output. While power does have a part in that, it certainly isn't going to make all of, or even most of the difference in increasing/decreasing how far you can talk.
The one thing that determines range the most is propagation, which you/I/we have no control over at all. Of the several things we do have control over, the most likely 'thing' which can increase range is the antenna (as everyone has already said). Maybe the next thing is output power. And one part most people don't think about, is the receiver you have (radio). If you can't hear'em, it doesn't matter if they can hear you or not, you still won't be able to talk to them. Which is the whole point (unless you're doing the shoot-out thingy, and then you don't need a receiver for that at all. Do you?).
All antennas are not created 'equal', and where they are can certainly make a difference too. The majority of thought is that your antenna won't 'handle' that 110 watts. I sort of have a feeling that it could, but no idea if it -would-. It's power handling ability isn't what's in question (much).
How much you plan to feed that amplifier is also questioned, and I think that's certainly something to think about. Most transistors can be 'tickled' with less power than most people realize. And since you've doubled your radio's 'normal' power for extended range, you may want to 'un-double' it to feed an amplifier. Too much 'tickling' isn't funny any more, it's called torture, it harms the amplifier.
All of this is sort of thinking "out of the box", right? No big deal until -not- thinking "out of the box" ends up making you think "I'm out'a 'bucks'!".
  #8
Old 10-30-2009, 07:19 PM
Senior Member
hotrod is on a distinguished road
Default
if ya really wanna run a amp with that antenna get a kl-40 .youll have to back the 8 watt
down to about 2.youll be safe with this amp.HOWEVER i must say just get a better
antenna.i once has a cobra19 old metal case one with a wilson 1000 mag mount
i could talk bout 15 18 miles also had a power mic on it as well
__________________
magnum delta force
magnum omega force
uniden grant
cobra 2000gtl
sirio z180
skythumper65dx
  #9
Old 11-01-2009, 09:50 AM
psycho's Avatar
Senior Member
psycho is an unknown quantity at this point
Default
Quote:
Cobra 19Ultra and a Lil Wil? Don't expect too much from that combo and don't run an amp on that antenna.
Kind of like playing a par 5 hole with only a putter.
__________________
It's a lot cheaper to supercharge a wattmeter than to buy a bigger amplifier!
  #10
Old 11-02-2009, 08:34 AM
Senior Member
The Jerk is on a distinguished road
Default
I've read on several forums where guys damaged their equipment running small amplifiers through the Lil Wil, and much less than the rated 300 watts.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
5 Pill homebrew linear problems crazy_179 Amplifiers 23 03-27-2009 12:34 PM
RM KL 500 Linear 116sd019 Amplifiers 9 03-01-2009 03:20 PM
Linear installation; Grounding & all that other good stu gohusan Installation & Station Setup 7 04-01-2007 04:09 PM
Kris Power Pump Linear Question broncoman529 Amplifiers 9 09-20-2005 11:15 PM
Take care in Re-Tubing your Linear... KLV 1000 Re-Visited! ; High Miler Amplifiers 6 08-03-2005 07:13 PM
Powered by vBulletin®
