Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Dont know nothin bout no caps
Reply
  #1
Old 11-07-2009, 09:26 AM
Senior Member
Splash1 is an unknown quantity at this point
Default Dont know nothin bout no caps
got a couple caps to put on the mobile for noise but i know nothing about them..thier 16v 10000pf..read somewhere that some of them have a hot n a cold and some dont..is anyone familar with the ones i have ? dont see any hot/neg marks on the caps..
__________________
splash..
Worldwide Radio Forum
  #2
Old 11-07-2009, 10:01 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Quote:
Well, 10,000pf equals 0.01uf, for starters. I don't know what type of noise you're working with, or what's causing it, but that might not be enough capacitance.
Assuming the problem is a motor with sparking brushes (typical), I wouldn't use a capacitor rated less than 50V. Such a spark can have some very high (and very short) voltage spikes.
Typically, the only type of capacitor that has polarity markings is an electrolytic - the large ones used as filters in power supplies. Ceramic disc capacitors are not polarity sensitive.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
  #3
Old 11-07-2009, 12:51 PM
Senior Member
moleculo has disabled reputation
Default
You can use electrolytic caps to help suppress ignition noise by putting it inline with your power feed to the radio. However, you need much bigger caps than the type you're suggesting. I would use at least twice the rated voltage of your device (bigger if you can, like Beetle said), and you're going to need something in the range of 30,000pf. That's just an off-the-top-of-my-head guess. The cap is going to be the size of a beer can.
The other thing you can do with a cap of smaller value is to combine it with an inductor like this:
Building a simple Alternator whine / ignition filter
  #4
Old 11-07-2009, 09:34 PM
Beetle's Avatar
Senior Member
Default
Again, 30,000pf = 0.03uf. Don't confuse the prefixes! You won't find any 0.03uf electrolytics, but 30,000uf would be pretty easy to come by.
Also, the capacitor doesn't go "in line" (meaning "in series") with a DC line unless you want to block all the DC and just pass the AC component (being the noise). Call me picky, but I'd install such a capacitor ACROSS the line, rather than IN line.
Pico = 10^-12
Nano = 10^-9
Micro = 10^-6
__________________
73 de K7KBN
  #5
Old 11-08-2009, 01:46 AM
Senior Member
Default
Beetle, you're absolutely correct, obviously. Not pf...but uf, of course...just typing without thinking there. Good catch. Maybe "inline" isn't a good choice of words? The point is, you hook up the positive lead to the positive terminal, and the negative lead to the negative terminal.
  #6
Old 11-08-2009, 09:55 AM
Beetle's Avatar
Senior Member
Default
Zactly - putting the capacitor ACROSS (sort of "in parallel" with) the power supply, ideally as close to the radio as possible.
__________________
73 de K7KBN
  #7
Old 11-08-2009, 10:04 AM
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
Quote:
My turn to be picky. You want the caps as close to the noise source as possible in order to prevent radiation that can be picked up by the antenna. If the noise is present on just the power leads then placing the caps close to the radio will work.
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
  #8
Old 11-12-2009, 06:07 PM
Senior Member
9C1Driver is on a distinguished road
Default
Why not just by a Magnum filter cord and be done with it. They work great. If it's still bad after that then you might have to attack the problem at the source of the noise. Adding a filter to a fuel pump on a Ford is one such example
  #9
Old 11-12-2009, 06:39 PM
Beetle's Avatar
Senior Member
Default
Quote:
Fully agree - I was assuming (I know) that it was conducted rather than radiated noise.
__________________
73 de K7KBN
  #10
Old 11-13-2009, 08:32 AM
Administrator
Default
In all my 30+ years of operating mobile radio I have yet to be blessed with a case of conducted noise. ALL my noise issues have been of the radiated kind.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
questions about tantalum caps loosecannon Tech, & Repair 11 11-02-2007 06:23 PM
Replacing caps in a tube amp dt1561 Tech, & Repair 3 07-30-2006 07:55 PM
DISC CAPS.. An Army of ME CB Band and CB Radios 4 04-17-2005 03:55 PM
Powered by vBulletin®
