Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
KLV-550
Reply
  #1
Old 11-23-2009, 01:45 PM
Oldtimer's Avatar
Senior Member
Oldtimer is on a distinguished road
Default KLV-550
How can ya tell if a pill is bad in a KLV-550.
All I can get out of it is 275 watts.
I have tried five different radios that dead key 2 watts and swings to 15.
When I lived in NJ my friend got 550 watts out of his driving it with a Cobra 25 dk 2 watts and swing to 10 watts.
Thanks GOD BLESS
__________________
My Toys
Galaxy DX 95T2
Galaxy DX 929
Uniden PC66XL
Connex 3300
2-Cobra 25 LTD Classics
KLV 550
Pyramid PS-26 KX
Imax 2000
GOD BLESS
  #2
Old 11-23-2009, 02:00 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
What does the SWR look like?
That would be the first place I would look.
I just did a little research on this amp.
It appears that this particular amp is prone to failure/damage if the SWR isn't nearly ideal.
Overdriving it - I don't think you did that - would also create damage. They are a bit sensitive - I guess. Never owned or used one myself. Just Texas Star and Palomars.
"...RM KLV 550 transistorised mains amplifier
A solid-state (transistor) amplifier which is powered directly from the mains.
Output power is variable in 6 stages, giving outputs from approx 50W to 300W (depending also upon input). There is a variable 26dB pre-amplifier.
The front panel also has a 13.5V outlet with a maximum current of 3A. This is suitable for powering a low power radio or various low power accessories.
This has the advantage over it's valve equivalent of giving instant output (no warming up) and requiring no tuning.
The disadvantage is that transistors are much less tolerant of a high swr and will blow if the swr is too high..."
-KnightsCB-UK
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #3
Old 11-23-2009, 03:18 PM
Oldtimer's Avatar
Senior Member
Default
My swr's are below 1.4 with the amp on.
Thanks
__________________
My Toys
Galaxy DX 95T2
Galaxy DX 929
Uniden PC66XL
Connex 3300
KLV 550
Pyramid PS-26 KX
Imax 2000
GOD BLESS
  #4
Old 11-23-2009, 03:22 PM
Robb's Avatar
Yup
Exclamation
Quote:
Thanks
Does the SWR get worse than 1.4 as you talk/modulate?
__________________
  #5
Old 11-23-2009, 03:44 PM
Oldtimer's Avatar
Senior Member
Default
Nope!
__________________
My Toys
Galaxy DX 95T2
Galaxy DX 929
Uniden PC66XL
Connex 3300
KLV 550
Pyramid PS-26 KX
Imax 2000
GOD BLESS
  #6
Old 11-23-2009, 05:17 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
You wont see much more out of that amplifier I see between 300-400 if you know anyone looking for one I have one Ill sell I dont use it but I will say its a nice sturdy amplifier.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #7
Old 11-24-2009, 04:35 AM
Highlander_821's Avatar
Amour d'Ecosse
Highlander_821 is on a distinguished road
Default
I'd say there is nothing wrong with your amp. RM's model numbers are not indicative of the units' power output. (Shoot, they named their 2 by MRF455 amp the KL-400!!!!) My 550 with do about 250-260 on AM and right around 300 SSB. But it sounds like crap on SSB---either it is class C, or mine has some issue with the bias.
__________________
Highlander, NA-821 on 11 Meters.
N9RZF, David on Ham Bands.
Yaesu FT-847, Galaxy DX-2517, President Lincoln, Cobra 150 GTL, Uniden Grant LT.
  #8
Old 11-24-2009, 08:32 AM
Senior Member
bob85 is on a distinguished road
Default
i agree with tony and highlander, you dont have a pill down, the kl550 only manages about 300w fm or ssb with 10w drive,
they sound poor on ssb because the antenna relay switches before the bias circuit, ssb audio starts with no bias at all and drops back to no bias between words and syllables,
the bias circuit is not stable when it is switched on been fed from the main unregulated dc supply that swings from around 30v at low drive levels to around 25.5v@300w,
when bias finally turns on it turns on too high but falls back as drive level is increased,
the onboard regulator circuit would be much better used as a regulated supply for the bias circuit,
the psu has nowhere near enough reservoir capacitance for an unregulated or regulated supply of that current,
i posted a quick fix a while back that allows the bias to turn on just before the antenna relay ensuring class ab operation at all drive levels and distortion free audio,
heres a pic where i tacked a variable resistor in to test the idea,
KL550 BIAS FIX pictures by ukmudduck - Photobucket
__________________
tom bearden taught me that quantum entanglement allows thought to travell faster than the speed of light, this explains why at first you can think somebody is smart but if you wait a while you will see they are not very bright at all.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
