Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
OK, what'd I do?
Reply
  #9
Old 12-23-2009, 04:02 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Good advise has been given.
Look and see if D51 is even there. When the radio is hooked up backwards D51 should short and blow the fuse. This blocks reverse current from entering the audio circuit.
Possibilities is the radio had the incorrect fuse installed. This would blow D51 and open the path accross it. Reverse voltage now feeds into the audio chip (IC 5) and takes it out along with the windings in the transformer (T16).
Another possiblity is the radio has been hooked up backwards several times in the past and the diode went quick when you hooked it up.
These radios had some hefty solder traces back then. So the audio circuit takes the brunt of the load. Most radio's today would blow the trace.
  #10
Old 12-23-2009, 05:14 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default
I have to ask this, what value of fuse were you using or were you using one at all? A properly rated fuse should have blown instantly if the protection diode was good and certainly blown in far less than a minute if the diode was bad or missing. If all else fails hook it back up again and watch for the point of origin of the smoke.
__________________
There are 10 kinds of people in this world. Those that understand binary and those that don't.
  #11
Old 12-24-2009, 06:37 AM
KB1TPX's Avatar
KB1TPX is on a distinguished road
Default
Thanks all for the advice. Gonna be pretty busy and out of town for a couple of days. I'll try everything when I get back. Too bad I don't have a mobile rig for traveling, oh well worse things have happened.
Merry Christmas everyone!
__________________
TENTEC 544, G5RV @ 36'
"The more educated you become, the more dangerously you live."
  #12
Old 12-30-2009, 07:25 AM
KB1TPX's Avatar
Default
Shipped it out to Key CB in Warren, IN today. He figures it's the audio chip that fried. ($25.00) Well, whatever it is, he'll fix it.
__________________
  #13
Old 12-30-2009, 07:39 AM
Peddler's Avatar
SWR (sandwich with rum) Expert
Peddler is on a distinguished road
Default
Quote:
LOL ... not LOL.
__________________
  #14
Old 12-30-2009, 10:57 AM
KB1TPX's Avatar
Default
Quote:
Originally Posted by Peddler View Post
LOL ... not LOL.
The fuse was definately too big. I had just bought the rig 2nd hand and neglected to look at it. It wasn't until I crossed the wires and damaged it that I checked and found a 30A fuse. Lesson learned.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
