Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
139 XLR Help Please
Reply
  #1
Old 04-21-2010, 11:53 AM
packrat's Avatar
Senior Member
packrat is on a distinguished road
Default 139 XLR Help Please
I recently picked up a Cobra 139XLR in decent condition. It received and transmitted both am and ssb, but output and modulation were both low. I got on CBtricks to get the adj. points for the radio, and when I started to adj., I started with VR8, which said it was AM power. I started the adjustment into a dummy load, and the power started to come up to around 5 watts. So I said, Cool. But when I keyed up next time to recheck it, I had no power or modulation. Relay kicks, and I did clean the contacts. Receive is fine. Changing the adjustment makes no difference. That was the only adjustment I made. When I key up on ssb, the radio clicks and the lights dim, kinda like a short?
Can anyone out there clue me in to what I did? Seems everything I touch lately dies. Im afraid to take a leak!!
__________________
Incentives are important.....I learned that in rehab!
  #2
Old 04-21-2010, 12:59 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Just some thoughts...
Turn the AM power VR back down to where you found it and re-check. You might have even snapped the final. Hook up an external power supply; maybe the stock one is ready to die...
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #3
Old 04-21-2010, 01:27 PM
packrat's Avatar
Senior Member
Default
Robb,
Doesnt matter where I turn the VR, it still has the same problem. When I key up in am, it trips the relay, but has no audio or power out, no dimming or other signs. In sideband, it seems like it is clicking the relay on and off, like the radio turning on and off repeatedly, and dims the lights.
__________________
  #4
Old 04-21-2010, 02:42 PM
Senior Member
tecnicoloco is on a distinguished road
Default
Check the AM Regulator C1419 and Capacitor C-179 2.2microfarads tantalum cap,you can replace the cap with a regular capacitor,watch the cap polarity.
Cap is located behind the relay and the regulator is bolted on the side.
The first thing to do with this board is look for the most common failure. It is C179. That is a small blue tantalum cap near the final. Right in front of the final and close to the White wires feeding the Final and Driver, you can see it next to a somewhat large RF choke. Here are the symptoms:
On AM the lights dim with no output.
On SSB the radio cuts out completely then the relay starts to chatter.
Removing C179 will solve this problem. You can simply remove it if you wish. Modulation will increase somewhat so you may want to just leave it out of there.
Credit to N9EFJ.
PHP Code:
http://trc458.n9efj.net/
Check the above page for schematics and more info for your radio.
Tecnicoloco
__________________
Kenwood TS-120S,MC-50 Mic,Yaesu FP-700 PS,Antron 99 W/GP Kit at 20Ft.,4 Elem Sirio Optimized for 27.555 Mhz. RP789 Design at 12 Ft,MFJ 949 Tuner.
  #5
Old 04-21-2010, 04:57 PM
packrat's Avatar
Senior Member
Default
That was it. Thank you for the info .
When I was in there, I noticed that both CI 54 and CI 55 were cut. Any ideas why?
Thanks again for all the help.
PR
__________________
  #6
Old 04-22-2010, 04:52 AM
packrat's Avatar
Senior Member
Default
I also see that ssb power is pretty low. Any tune up points I should try for this?
PR
__________________
  #7
Old 04-22-2010, 09:13 AM
Robb's Avatar
Yup
Default
Cobra 139XLR
Couldn't help but notice all of the service bulletins on this radio. They even had correction bulletins for the service bulletins - yikes. Either it had a lot of problems, or there were so many sold that a large database had been created. Probably both. Never owned one of these myself.
__________________
  #8
Old 04-22-2010, 11:25 AM
packrat's Avatar
Senior Member
Default
Thanks for the link Robb. I think they sold quite a few of these radios. They are one of my favorite radios.
I will look into the link.
PR
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cobra 139 XLR 43Echo695 CB Band and CB Radios 1 12-24-2008 06:07 PM
Powered by vBulletin®
