Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Broken Resistor On a Palomar 255 Amp
Reply
  #1
Old 07-24-2010, 05:36 PM
Junior Member
Buckshot555 is on a distinguished road
Default Broken Resistor On a Palomar 255 Amp
I have a Galaxy 225 Amp that is an EXACT copy of a Palomar 225, blue face. I picked it up used at a cb shop for 50 bucks, the owner said it didn't have full output power. It seems to be a pretty sturdy little amp, but the problem is that it only puts out about 50 watts.
When I inspected it, I found a resistor that has broken one leg off of its solder joint, the rest of the amp seems fine. The pre amp works amazingly and the first radio check I requested got me a "you sound somewhat scratchy" but that was with a cheapo mag mount antenna on my truck and the reply was from another CBer 41 miles away in the woods!
Its my first amp and though it works great already I just want to get all the power out of it.
There is another resistor on the board that broke in the same spot that has been fixed by the previous owner. It seems he didnt even remove the board from the chassis and just put new solder on one leg of the resistor and connected it right to the board.
I have tried to remove the board but it seems to be impossible without desoldering the front switches and drilling out the rivits that hold the SO 259 connectors to the chassis. I tried to remove the four screws that hold on the faceplate, but it still was connected to the frame somehow.
My question is how can I remove the board from the chassis to solder the leg back on? Also, could I just patch it the way the previous owner did and not have to remove it?
I know that boards have a solder side and a component side but it seems that the pathways on the board are on the component side as well and the components are just soldered to parts of exposed pathways on the component side. If this is the case, I should be able to get away with just soldering the resistor back on the component side right?
Its my first amp and I'm really looking forward to a response so I can get this guy up and running and make contacts from 82 miles away!!!
I have added a few pictures to help everyone get a better idea of what's going on. The second and third pictures are of the broken resistor and the fourth is of the broken resistor that was fixed by the previous owner.
  #2
Old 07-24-2010, 05:49 PM
GLR GLR is offline
Keeping It Good Natured
GLR is on a distinguished road
Default
Quote:
82 miles?
awesome
  #3
Old 07-24-2010, 06:00 PM
Junior Member
Default
Ha ha. Well I was saying that because getting the other pill to fire up would double my output power and maybe double my distance....
In all fairness, the other guy was 41 miles away with a tower.....
  #4
Old 07-24-2010, 06:18 PM
Senior Member
bob85 is on a distinguished road
Default
buckshot, the 820pf compensation cap is missing from the output transformer
__________________
tom bearden taught me that quantum entanglement allows thought to travell faster than the speed of light, this explains why at first you can think somebody is smart but if you wait a while you will see they are not very bright at all.
  #5
Old 07-24-2010, 06:22 PM
Junior Member
Default
Is that the brown square looking capacitor I saw in some other pictures of this style amp? What does it do? Can I buy another one and solder it in place?
Also would you happen to know what it is that the broken resistor controls?
  #6
Old 07-24-2010, 08:58 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
It's one of 2 feedback resistors..
  #7
Old 07-24-2010, 09:21 PM
Senior Member
Default
the cap compensates inductive reactance in the transformer primary, you can buy one and solder it in,
the unsoldered resistor is as mack says one of the feedback resistors, along with other feedback components they do several things, lower gain, lower input/output impedance and often stabilise unstable amplifiers,
the other resistors that have had some hammer look like part of the input attenuator.
__________________
  #8
Old 07-25-2010, 08:42 AM
Jock Supporter
Default
Input padding which Bob85 eloquently stated which without the use of the smokeless resistor would failed long ago, Galaxy don't like 10ohm smoke smell.
A guy could up the wattage of that resistor and rid one's self of the ugliness but it's an easier solution to just keep the input power from the radio below 5 watts which that resistor is rated for.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Looking for info on Palomar MOSFET Amp loopy Amplifiers 28 10-17-2010 10:27 AM
Powered by vBulletin®
