Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
Boomer Deluxe 500 Base amp
Reply
  #1
Old 10-06-2010, 07:40 PM
Junior Member
Buckshot is on a distinguished road
Default Boomer Deluxe 500 Base amp
Hello i was wondering if anyone has ever wired a on off switch or variable speed switch for the fan on the rear of amp? My microphone picks up the noise where i like to run my turner +3B desk mic modulation. The amp is a straight 4 pills with 1446 trans. So how could i add this switch, what type of switch could i use? This amp also has the two lugs on front for mobile power supply. Any help would be appreciated.
  #2
Old 10-06-2010, 09:22 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
You will need a variable it would go inline with the wires that run to the fan it would be spliced in. It would work kind of like a dimmer switch on a house light that is how the speed control could be set
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #3
Old 10-07-2010, 09:33 AM
Oatmeal's Avatar
Senior Member
Oatmeal is on a distinguished road
Default
I had the same problem here with my power mic picking up the noise from the fan...
I put my amp down near the floor and off to the right side away from my mic...it works good now......just a thought..
  #4
Old 10-11-2010, 07:59 PM
Junior Member
Default
O.K appreciate your replies, I've been busy & no time to reply.
  #5
Old 10-11-2010, 08:55 PM
TonyV225's Avatar
Default
Hence the slang term "Footwarmer"
__________________
  #6
Old 10-12-2010, 06:13 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default
As a previous user of power microphones, including the Turner +3B and D-104, I say that the gain is too high. Your microphone should not be able to pick up the fan noise. I know a lot of guys crank the mic gains up and then lean back in their chairs about two feet from the mic and that's not the way to do it. Your audio would be much better with lower gain and speaking close to the mic. Just offering some advise learned from being in this crazy hobby for 33+ years. Use it if you want and ignore it if you wish.
__________________
There are 10 kinds of people in this world. Those that understand binary and those that don't.
  #7
Old 10-12-2010, 06:29 AM
packrat's Avatar
Senior Member
packrat is on a distinguished road
Default
Turn down the mic gain.
__________________
Incentives are important.....I learned that in rehab!
  #8
Old 10-12-2010, 07:44 AM
TonyV225's Avatar
Default
Alot of people think you have to turn up that gain on that power mic so you can boom the airwaves Thats not the case all you need to do with a radio thats been peak and tuned is set the radios mic gain at 12:00 position and your mic gain by using a simple test using AM or SSB key the mic and watch your radios meter or an outboard power meter you shouldnt see any audio movement this is where SSB is the easiest mode because there is no carrier but even AM mode will show if theres audio there moving the needle above and beyond its carrier point.
Seeing movement on a deadkey is no good this means that you have your gain set to high and you need to back it down. some people do not have alot of background noise but when talking almost have that echo in the room that also comes from the gain set to high. You have to find that happy medium for each application or setup rather it being a mobile or base eitherway steps have to be taken to set it propery or your going to bring all kinds of noise with your voice on keyup.
As stated if you are one of these people that to like to (kick back) in the easy chaiir and talk into the mic then I suggest you get a handheld because if you dont plan on yelling to be heard in the microphone then you and others on the frequency are kjust going to have to deal with the background noise
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LOOKING FOR A 300 - 500 WATT BASE AMP FOR A FRIEND TonyV225 CB Radio Gear SwapShop 2 04-02-2010 03:50 AM
Golden Falcon Base Amp - 10 tube skullman64 Amplifiers 6 03-20-2010 10:40 PM
Boomer Deluxe 500 help please chip3655 General CB Services Discussion 13 10-12-2009 04:39 PM
Boomer Deluxe 300 Base amp/supply combo Audio Man General CB Services Discussion 1 04-23-2009 05:22 PM
Powered by vBulletin®
