Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > General CB Services Discussion
Amateur Callsign Lookup
Enter Callsign:
C.B Help...
Reply
  #9
Old 12-07-2010, 06:10 PM
loosecannon's Avatar
break on through
loosecannon is on a distinguished road
Default
not sure if this helps here, but having just re-wired a super sidekick mic for someone; i have the info sitting here.
white/clear-audio
shield-ground
black-TX
red-RX
most times, and older obscure CB will be the same board as other popular radios.
for example, your JC Penney 981-6247 is the same as these radios:
US and Canadian SSB, PTBM048A0X, PTBM058COX:
AWA/Thorn 1503, Bowman CB950, Cardon Iroquios 40, Colt 480, 485DX, 890, 1000, 1200 (Excalibur), Gemtronics GTX77, GE 3-5825A, HyGain 2705 (V), 2785, 3108 (VIII), J.C. Penny 981-6247, JIL Citizen MPL-5, JIL SSB-M6, Lafayette Telsat SSB80, SSB120, SSB140, Midland 78-976, 79-892, Palomar 2900, Pearce-Simpson Super Panther, Bengal Mark I, RCA 14T302, Truetone CYJ4837A-87, Universe 5600: <L7, L11, L13, RV12-AMC, RV2-ALC, RV11-SSB Mic Gain, VR4-AM Power>
using this, you can find another radio that the info is more readily available for, such as the Boman CB950.
here is the mic wiring for your JC Penney radio, and then the mic wiring for the super sidekick to that radio.
1- Audio
2- Shield
3- Receive
4- Transmit
so, for the super sidekick, that would be:
1-white/clear (the one with the shield wrapped around it)
2-Shield/ground
3-red
4-black
hope this helps,
__________________
https://i.chzbgr.com/maxW500/1912864512/h0491035C/
  #10
Old 12-08-2010, 06:44 AM
T23 T23 is offline
Senior Member
T23 is on a distinguished road
Default
Thanks loosecannon for the info, I couldn't find the colour to function chart for the SSK anywhere. Once I get a 4-pin lug from radio shed I'll give it go.
Geez that radio chassis was put into alot of radios, do those even look similar to mine? I know there's a colt black shadow mobile that looks like this one but without the faceplate.
T23
  #11
Old 12-08-2010, 02:28 PM
break on through
Default
im sure they all looked a bit different.
its always been a popular thing in the CB manufacturing world to use the same innards with a bunch of different looking boxes.
still is today. the EPT3600 series boards are everywhere.
hope it works out for you.
__________________
  #12
Old 12-08-2010, 02:31 PM
T23 T23 is offline
Senior Member
Default
I got the 4-pin lug tonight, I am gonna put in on the cord this evening...
I'll let ya'll know how it goes...
T23
  #13
Old 12-09-2010, 06:18 AM
T23 T23 is offline
Senior Member
Default
OK, I tried wiring it exactly like the diagram you posted and all it does is squeal, I think the audio amplifier has gone, it still works with the hand mic I rewired, I even tried wiring it the same way as my hand mic, but it either TXes constantly or squeals...
T23
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Convert PC Power Supply for C.B use? T23 Home Brew 22 12-19-2010 06:22 PM
How do you re-alighn A C.B? T23 CB Band and CB Radios 2 11-08-2010 05:06 PM
Powered by vBulletin®
