02-23-2011, 07:53 PM
 | Yup | | Join Date: Dec 2008 Location: Silicon Valley CA, Storm Lake IA
Quote:
Originally Posted by loosecannon i am going by the SAMS for the 8719 madison, so it should be pretty close, but some things may be different.
TP1- is the output of L20, which connects to R106 and R107
i cant find any TP5 in the alignment or in the schematic.
what is the adjustment for?
if you need others, post them and i will see which ones line up.
LC | "TP1- is the output of L20, which connects to R106 and R107" is actually TP2 in the Grant XL. The 148GTL schematic shows the same thing as you described. Not the same. There is a difference from what I see on the Grant XL and the 148GTL. I have confirmed this by checking so far. I've done all of the synthesizer section part - except for the adjustment for L19. http://www.radiomods.co.nz/grantxlalignment.html
"TP5" - is "R86":
"Input of frequency counter to TP5 (at back near Q19).
Ch. 19, USB - CT2
Adjust for 7.8015MHz +5Hz, -0Hz.
Ch. 19, LSB - L30
Adjust for 7.7985MHz +0Hz, -5Hz.
Ch. 19, AM, Transmit - L31
Disconnect TP7 and TP8.
Adjust for 7.8000MHz +5Hz.
Reconnect TP7 and TP8." I hope to find some more info - Thanks LC!
This is what I need the location for:
"Input of DC meter to TP1.
Ch. 40, AM
Clarifier Midrange
L19 Adjust for 3.6 volts." I think the info is in SAM's Vol. 221 . . .
__________________ BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000. MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770. "...2 WR-011..."
