Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
My coax debate
Like Tree11Likes
Reply
  #17
Old 02-19-2012, 03:23 PM
Senior Member
vo1ks is on a distinguished road
Default
I challenge you to find a single manner in which the PL259 is superior.
Oops, other than at DC... I'm assuming we're talking RF work here.
  #18
Old 02-19-2012, 04:20 PM
359's Avatar
359 359 is offline
Senior Member
359 is on a distinguished road
Default
Have you seen the tests?
Sent from my iPhone using Tapatalk
__________________
"Contradictions do not exist. Whenever you think that you are facing a contradiction, check your premises. You will find that one of them is wrong."
- Ayn Rand (1905-1982)
  #19
Old 02-19-2012, 04:40 PM
Senior Member
Default
Would doing measurements personally using an Agilent E5071B network analyzer count as seeing them? If so, yes, I've seen the tests.
  #20
Old 02-19-2012, 05:11 PM
359's Avatar
359 359 is offline
Senior Member
Default
Since you have good equipment, you know UHF connectors aren't so bad are they?
__________________
  #21
Old 02-19-2012, 05:26 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
The ONLY time I have seen anything where the N was inferior to the UHF type PL-259 was a test that was done that determined that in very high power situations the centre pin of the male type N connector may not handle the higher RF current than the UHF due to it being much smaller in size.This is not normally an issue at amateur power levels. As for losses and constant impedance, the N wins every time especially at VHF and above. For normal amateur uses, yes, the UHF connector is not that bad and is often used at 2m. "Often used", and "not that bad", are different however than "could be improved upon".
http://www.qsl.net/vk3jeg/pl259tst.html
hookedon6 likes this.
__________________
  #22
Old 02-19-2012, 05:31 PM
Senior Member
Default
They beat spade terminals hands down.
  #23
Old 02-19-2012, 05:44 PM
359's Avatar
359 359 is offline
Senior Member
Default
I'll have to go back and see where I said the N was inferior to the UHF .......... Hmmm, I can't seem to find it. This damn phone, can you quote it for me so I can find it?
Oh, BTW, how many dB better was the N over the UHF at VHF or at HF, and which connector arced 1st at high power?
__________________
  #24
Old 02-19-2012, 05:58 PM
Default
Type-N connectors are considerably better than SO-239 / PL-259 connectors in every way I can think of.
Quote:
Originally Posted by 359 View Post
Have you seen the tests, or are you drinking the kool-aid?
By asking "Have you seen the tests, or are you drinking the kool-aid?" in response too "Type-N connectors are considerably better than SO-239 / PL-259 connectors in every way I can think of." is a pretty good indication that you disagree with what VO1KS said. Since VO1KS said the N is better than the UHF and you apparently disagreed with what he said it can be inferred that you think that the N is inferior to the UHF. Let's not get into a pissing contest and kool-aid is for kids.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Resonating coax BOOTY MONSTER Meters, Mics & Other Accessories 26 01-27-2012 12:55 PM
very interesting article about burying coax BOOTY MONSTER Installation & Station Setup 1 11-25-2011 07:24 PM
Common Mode Currents Sonwatcher General CB Services Discussion 3 07-30-2008 08:45 PM
Adjusting SWR with amp T-bone CB Antennas 59 03-27-2008 06:48 PM
BUYING BELDEN COAX CABLE-BEWARE lords Announcements & Open Forum 0 11-06-2007 07:14 PM
Powered by vBulletin®
