Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
yaesu ft101e
Like Tree5Likes
Reply
  #1
Old 04-16-2012, 11:08 AM
Se7en's Avatar
Se7en is on a distinguished road
Smile yaesu ft101e
Is this a good choice for a first time old school purchase? it will be used on 10m and cw on other bands.
Know of a site that talks about its operation...?
__________________
NSAWe're watching you!
  #2
Old 04-16-2012, 12:07 PM
Wire Weasel's Avatar
Senior Moment
Wire Weasel is on a distinguished road
Default
Yup, They have a long standing webpage dedicated to the entire 101 line beginning to end.
Yaesu FT-101 HF Transceiver Web Page presented by Fox Tango International
A 101 series CAN be a good radio. All depends on who all has owned it and what kind of shape it is in. You ever have to be aware of their age and stuff can break down at any time. Then you'll be looking for somebody who can repair them and find parts....tough decision.
I would buy one ONLY from a seller who is CERTIFYING that it works 100% as should and will gladly take it back if it doesn't...... pay with a credit card or credit card through paypal. I wouldn't send anybody cash.
For AM operation you MUST have the optional AM Filter or you will be screwed. If you get a good rig but it doesn't have the filter....you can get them....but be prepared to shell out $125 bucks for one.
I've had a 101 EX and a 101ZD
Good luck
__________________
Welcome to the WWRF. Plenty of Free Parking and with 5,000 posts you get egg roll
  #3
Old 04-16-2012, 01:38 PM
Se7en's Avatar
Default
Good luck
I would only use it for usb lsb and cw. I cant believe the output is over 200w on ssb....is it hard to mod to do 11m?
Sent from my DROIDX using Tapatalk 2
__________________
  #4
Old 04-16-2012, 02:23 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
They are good radio`s I have had a couple of them, first radio I used on HF when I got my tech+
Take it easy on the 260 watt power rating...that is INPUT POWER, not output LOL
Running hard they will do 120/130 watts, depending on what band you are on.
AM mode, 25 to 35 watts.
They will get you on the air, and if you know how to work on them can be a good rig.
Right off the bat I would get a Service manual and re-cap the radio as a preventive step.
Another site to look at.
http://www.qsl.net/nw2m/
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
  #5
Old 04-16-2012, 02:30 PM
Default
The mod for 12 meters is un plugin a crystal in one of the Ten slots and replacing it with the mixer crystal for 12 meters.
Quote:
Converting 11 Meter band to 12 Meters for the Yaesu FT 101 series ..
Although this procedure hardly qualifies as a "mod" (too easy), it is certainly useful for the FT 101 series owner. Conversion to the 12 meter WARC band is as simple as replacing a crystal. The 11 meter xtal is replaced with a 30.52 Mhz 3rd overtone xtal in a HC-25/U holder as specified in the FT 101 series maintenance manual. No other modifications are necessary as the new band is close enough to the original that the current components work. To replace the xtal, remove the top cover and find the xtal board located at right front of the rig.
or 11 if you want to monitor down there
Quote:
For 27,000 to 27,500 Mhz use the 33.020khz crystal
27,500 to 28,000 Mhz use a 33,520khz crystal
and So on.
__________________
Radio-active
NASA/SOHO
  #6
Old 04-16-2012, 03:52 PM
Se7en's Avatar
Default
What the hell is input power ?...I don't do AM anymore unless its a am station over seas for rx only.
__________________
  #7
Old 04-16-2012, 04:06 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Plate voltage times plate current in short terms for a tube type amplifier as in the FT-101. It general terms it is the voltage applied to the finals times the current consumed by the finals. Are you sure you passed a test?
__________________
  #8
Old 04-16-2012, 04:14 PM
ahamoperator's Avatar
peanut whistle
ahamoperator is on a distinguished road
Default
The FT 101B was my first rig...Had it before I passed my Novice exam..Had
11 meters right on the front panel. If I remember right it would start at
about channel 3 and go up to 27.585 or so..Man, brings back fun memories.
Warm it up a good 20 minutes and it did'nt drift a bit.
At the time, when the Icom 745 came out I bought one and couldn't wait to
get rid of the 101. In hindsight I wish I had the old girl back..
The E-model is about the same but has a speech processor..Someone
correct me if I'm wrong
p.s. Mine also had a 250hz cw filter..man did that work wonders!
73, Keith
__________________
dah di dah dit --- dah dah di dah
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Yaesu FTM-350 APRS Review Moleculo Product Reviews 89 03-25-2013 07:29 AM
YAESU FT101E Ebay Amateur Gear eBay Auctions Ending Soon 0 02-13-2012 01:10 AM
New Yaesu FTdx 5000 Preview Moleculo HF Bands and HF Rigs 12 02-12-2010 08:23 PM
Low receive on yaesu ft101E Hf talker General Ham Radio Discussion 2 06-15-2007 07:54 PM
Yaesu FT101E HCD729 HF Bands and HF Rigs 1 06-25-2002 03:51 AM
Powered by vBulletin®
